Middle click browser?
Clearscreen
Unread post by Clearscreen » 15 Aug 2013, 06:56
Finally getting a chance to play with hollyhock more, but missing my middle click browser patch - ie I had a patch in the master that translated a mouse middle click to an "open browser" command using the old dashbaord module. Is there a newer method to achieve this? I'm assuming IML can do it, but my scripting knowledge is "beginners" and a quick poke around hasn't revealed an easy method yet... I'm also assuming I'm probably missing something obvious here and there's already a cracking new way to do it in hollyhock that I've missed, so apologies if it's blindingly obvious!?!
thanks in advance...
Unread post by nay-seven » 15 Aug 2013, 18:55
you can create a new data device ( add data in) with this patch ( create midi can be note 127 for example), then create a midi learn on the browser icon.
And save this new device.
Clearscreen
Unread post by Clearscreen » 02 Sep 2013, 05:00
Ah, I see - I knew there'd be an easy workaround! Thanks Nay!
Users browsing this forum: No registered users and 417 guests
