Video module - trouble
grabbs
Unread post by grabbs » 14 Jan 2013, 13:27
Hello everybody,
I have some audio tracks to synchronize whith a video. So i have used the video player. It worked good after codecs troubles (K lite codecs pack recommended in the manual section :" http://www.sensomusic.com/wiki/doku.php ... deo_player"
don't work on VAIO).
The problem is that the video screen turn black after 9m 36 s even if the video time is 12m01s.
The windows counter in the module still go on.
Happy new year !
Grabbs
Unread post by nay-seven » 14 Jan 2013, 15:09
Can't reproduce it here with a .mov file of 12 Mn
have you try different video format ( as it's seems you have trouble with codecs) ?
grabbs
Unread post by grabbs » 15 Jan 2013, 20:50
Thank you for your answer.
The video is an avi file. The missing codec was dvsd. I've downoaded an other pack and it was ok to read the video in Usine. The synchro seems to be ok whith the audio put in the sequencer.
The avi file is well read, completely in a player like VLC.
trail : frame rate, presets of the pack of codecs?
grabbs
Unread post by grabbs » 16 Jan 2013, 14:42
I've tried to see the preset of the codecs pack (ACE full edition, something like that) but find nothing. So the trouble of dark screen is still there.....
See you
Unread post by nay-seven » 16 Jan 2013, 18:48
I understand but as we can't reproduce it...not easy to solve :/
grabbs
Unread post by grabbs » 21 Jan 2013, 09:33
Do you need the video?
Users browsing this forum: No registered users and 517 guests
