Unable to open file
Ken29
Unread post by Ken29 » 26 Sep 2012, 22:55
Hi guys,
I have this patch in my laptop, I made different versions, moved it several time, and at the end when I cleaned the laptop and opened the patch, Usine was unable to open my audio files. The sound folder I kept was probably the wrong one. Usine search in the disk without any success. I changed the setup and pointed to the folder containing my files but Usine still can't open them.
How can I force Usine to relocated my sound files ?
Kenan
Unread post by nay-seven » 27 Sep 2012, 00:16
Strange cause Usine can scans your 2 sound folders ( sound files and alternative drive) to find missing files.
but you can also open your workspace (or patch) with a text editor, this way you'll see where was the first location.
Ken29
Unread post by Ken29 » 27 Sep 2012, 22:01
Ok,
I had been able to do it that way and to find the original path, but I can confirm that Usine is unable to recreate links for files in the sequencer even if it looks in the good folder.
Kenan
Unread post by nay-seven » 27 Sep 2012, 22:22
I didn't know you're talking about the sequencer, gone to investigate
thanks for your feedback
Ken29
Unread post by Ken29 » 14 Oct 2012, 19:03
Hi Yan,
Well I experience it once more with files in the sampler, Usine doesn't relink the file ! Cheers
Kenan
Users browsing this forum: No registered users and 944 guests
