I'm using Using as a custom pedal board for a live setup. When I route an instrument through my sound card using ASIO4All and Usine, I get two signals, one's effected and one's clean. If I mute my effects patch I still hear clean signal. If I stop Usine by pressing the space bar, I get nothing. Does anyone have advice for me? I usually use Using as an instrument so I haven't come across this before,
CCQ
Routing Question
CleverConQueso
tanabarbier
Hi!
I guess that you're problem is that it is Usine that is monitoring the input, so you may want to try to see if your soundcard's program (maybe not with ASIOforall?) has monitoring possibilities?
CleverConQueso
Thanks, Tana. I was hoping that wasn't it. I've got to get an audio interface anyway. Now I know why.
<EDIT>
I had it patched in Mono so the second channel was coming through un-effected. All better now. Thanks, team.
<EDIT>
Users browsing this forum: No registered users and 455 guests
