usine and sampletank - vsti loading problem
Can give us more informations...?
the version you use and what's happen when you load the DLL..?
Hi nay,
I tried : usine pro 5.80.004 , easine 5.80.004 and usine free 5.80.013 (all stand alone) > all do not work.
i get a pop up message: problem loading sampletank2 Vst.
in the patch a vsti panel appears but all parameters appear as "not valid" (but connections midi in , audio in and out are there)
again, no problem when using usine pro or easine 5.70.
i was talking about the sampletank version, if it's the free one i can test, not for the others ones
and any chance there's difference in your test..? i mean same partition/vst dir and so..? i know ik products are really sensible about path/authorization
sorry, yes it s the free version. 2.5.5b
the vst dir (and so the dll) is exactly the same in all my usine configurations (also same asio config)
ok, so I've tested the free version, no particular problem here in the last pro 5.80.013 one, or older...all works fine
so i don't know how to help you
well thank you. i will just try to reinstall the all thing again and hope to be more lucky this time
