Usine and wiimote
tanabarbier
Unread post by tanabarbier » 21 May 2012, 20:10
Hi everybody,
I'm starting to investigate this Usine and wiimote thing and I noticed that there is more than one "wiimote", has anyone had a bad experience with a specific kind of wiimote? Is there noticeable diference for a controler use? Has anyone tried with non-nintendo's wiimotes ?
Or has someone any other kind of advice before starting to use those?
Thanks in advance!
Unread post by nay-seven » 21 May 2012, 21:33
generally , guys use the real one, I'm not sure that the price difference worth the risk taking ?
just a thought , i own only the nintendo one.
tanabarbier
Unread post by tanabarbier » 21 May 2012, 23:27
I think you're right, it's just that the official one is a little bit more difficult to find here (Mexico, land of pirates...)
And is there a problem to use two at the same time on the same computer?
Unread post by nay-seven » 21 May 2012, 23:42
ok, i understand,
i never test myself but if you look at the wii modules you'll see the wiimote number inlet ( up to 4 ) ;)
tanabarbier
Unread post by tanabarbier » 21 May 2012, 23:45
Ok, thanks, and sorry for the stupid question :)
martignasse
Unread post by martignasse » 22 May 2012, 11:53
hi tanabarbier,
for infos, here i have the "under control" version of the wiimote,
work like a charm with usine, and with the Nunchunk too :-)
Users browsing this forum: No registered users and 531 guests
