can someone explain me the technical difference between vst and vst-i?
vst can have audio in. vst-i not. is it that? processor load?
cant i just use vst for effects and instruments and forget vst-i?
vst vs. vst-i?
Clearscreen
Some vst hosts will only load a vsti as the first thing on a midi track - for example ableton live. Otherwise I don't think there's any difference in performance?
You're right clearscreen, the differences are quite subtle and more technical. And you can load an effect in the VSTi version and an instrument in the VST one. It's really depends of your Host .
i see.
thanks!
thanks!
thinkpad t61, xp 32bit, 2gig ram, rme multiface // acer timelinex 3820t, win7 64bit, 4gig ram, NI komplete audio 6 // reaktor, battery, nuendo // roland hpd15
Users browsing this forum: Bing [Bot] and 495 guests
