MIDI auto harmony
hey there..
well, it's all in the script. changing the harmonies isn't that great of a deal..
voices might be, depending on your coding skills.
~ io
~ io
Yes I tried to add more voices and harmonies, but it's not so easy. I can't compile the script because something is wrong before main process.
And one more thing... the one note or pitch consist of several sound waves or frequencies that are conditionally harmonic. And this script make something like chords , yes? [or make harmony from another 4 harmonies]
- is it possible to make more complex harmony from those chords?
tanabarbier
It's not answering your question but this patch I made is a 32 bars chord sequence player, so maybe you could use the "chord calculation" part (those are chords, not scales, but that's a start). I remember that I started trying with this script and then gave up and patched it with a lot a cables instead of a few code lines (that I don't know the first thing about).
Here it is :Download
the main purpose of it was to make a play along type of thing for a jazz playing friend.
@tanabarbier : i've edit your link for the patch ,it was not working
tanabarbier
Aaaah thank you! You always save me from my web-incapacity !
thanks for opinion, I will try it out
Users browsing this forum: No registered users and 101 guests
