buzzzzzzzzz
joss0706
Unread post by joss0706 » 06 Feb 2012, 17:19
hi !
i'm trying to understand a little problem ...
when you turn the system "off" (with the space bar) while a sound is running, you have a sound (that i called a "buz" in the subject - i believe this is the note F) wich is played. I'm sure that anybody can see what i mean.
the same thing happen sometimes when i turn to the minimum value a fader connected to a "volume audio" module or when I press a "mute" button. I have to stop the sample whith the "pause" button" before turning the fader to minimum.
i think it doesn't happen everytime, ... i can't understand. it's quite embarassing to have a "biiiiiiiiiiiiiiiiiiiiiiiiiiiip" instead of a silence...
has anybody already been confronted to this problem ?
thanks
Joss
www.josselinarhiman.net
www.facebook.com/jarhiman
Asus N53J, Intel Core i5, Windows Seven
Unread post by nay-seven » 06 Feb 2012, 17:56
mm, quite strange..
have you try different settings in global setup/system/ global speed...?
joss0706
Unread post by joss0706 » 06 Feb 2012, 19:41
no ... but it's really strange, i just replayed a song, and it worked perfectly... no buz ... it's only sometimes ...
i will keep a look, ...
Joss
Unread post by nay-seven » 06 Feb 2012, 20:05
ok, so maybe more a program running in the background..?
any antivirus, backup program who can create cpu spikes...?
CleverConQueso
Unread post by CleverConQueso » 06 Feb 2012, 22:08
Joss-
Is it like when you stop Usine, a little tiny snippet of the last sound that was playing is looping really fast making an annoying loud squeal? If so, I've had a similar problem that has come and gone between updates. I think the cause of what I experienced is addressed by playing with the ASIO settings. I use ASIO4All and when you update, you edit these settings. Try playing around with the buffers and latency and see if maybe it goes away.
-CCQ-
gurulogic
Unread post by gurulogic » 06 Feb 2012, 22:28
I have the same problem almost all the time. I am using Usine to process external audio, RME Multiface II audio card..
joss0706
Unread post by joss0706 » 07 Feb 2012, 02:34
in my workspace, the problems occures only on my second out (i have a motu ultralite mk3 hybrid, with 10 outs), wich go to afilter wich return in my interface. i think this creat a latence, ... (thanks CCQ)
it's really curious, but i found that the problems disappeared by truning of the "smooth" function on my volume audio module. (without changing my global setup)
i did'nt want to desactivate this function, so i looked for other solutions.
i finally changed, in the global setup, the "refresh speed" and the sound disappeared.... (i changed also the number of samples, to be sure)
thanks for your help,
Joss
Joss
caco
Unread post by caco » 07 Feb 2012, 09:04
I sometimes get the same problem too, it sounds like the last bloc of sound doesn't get cleared and keeps playing. It has seemed to come and go for as long as I have been using Usine. Some versions were worse than others but I never managed to find a way of reliably reproducing it.
GDLive
Unread post by GDLive » 08 Feb 2012, 12:14
I don't know if there is a link, but I've mainly similar comportment as soon as disable the last active track with audio out in patches.
Users browsing this forum: Bing [Bot] and 461 guests
