Create new GUI for existing commercial VSTi?
UsineHeaven
Unread post by UsineHeaven » 06 Dec 2011, 01:02
I saw that much is happening in Usine updates :) Just a short question actually explanation on what I want to do.
Import (open) a VSTi into Usine >> Create e 'new' GUi for it >> open it (with its NEW GUI) in Cubase.
Possible?
One button on that VST don't have ability to be controlled by Midi CC, but I want to address it tp my external midi controller. That is the main reason of why I want to do it.
I will appreciate nay answer. Thanks in advance!
Cheers.
Unread post by nay-seven » 06 Dec 2011, 09:22
hello
glad to see you back,
yes, no problem, the only condition is to have the original dll in you vst folder, cause Usine don't export/include it in your work
i suggest you to use Easine for this ;)
UsineHeaven
Unread post by UsineHeaven » 06 Dec 2011, 11:40
Thanks, this is good news :)
OK, I will start soon and let you know how it goes.
Cheers.
Users browsing this forum: Google [Bot] and 508 guests
