Anybody has an idea where to look? Maybe some settings in IE8 or Windows that I should check? Of course, it could be some security stuff on the network, but I didn't have this problem with the old XP machine.
No login from one computer
I have trouble logging in on my work machine, a Lenovo with Win7 32 bit running IE8. The login window with username and password shows and it looks as if I'm being logged in, but no...
just test with IE 8 /win 7 32 too, no problem here sorry..
CleverConQueso
Try rebooting to 'safe mode' (F8 at boot right after the beep, i think). If you can get logged in that way, try running 'msconfig' at Start|type 'msconfig' and go to the startup tab. Uncheck everything and then reboot. If that helps, run it again and try checking three or four at a time til you find what's keeping you out. I think the login box is/was called MSGina, so if anything modified that (remote access VPN?) that could do it.
@CleverConQueso: I meant logging in on the forum.
I tried to create another user, but it didn't help.When I have the time, I try to install some other browser like Firefox or Opera, and see if that helps.
CleverConQueso
Oh. Yeah. Duh. My login doesn't save on IE at home. I use chrome to use the forum. At work we've got IE8 and that works OK but I use it less.
I use IE7 at work at it is random, sometimes I can log in fine then I will have a few days where I can't login then back to normal again for a few weeks. Always works in FireFox and Opera though.
Maybe you could try to open internet explorer without addons (start/programs/accesories/system tools).
or check if you have the compatibility view for the internet explorer activated, look for it at the top right of the address bar
Just installed Opera, and it's working fine, so I'm not spending more time on this matter. Thanks, for all the suggestions, folks!
Users browsing this forum: No registered users and 136 guests
