Hi, I want to work outside the equal-tempered scale. As my first experiment I want to work with a few pitches, for example 100 hz, 200 hz, 300 hz, 400 hz and 500 hz.
Could you recommend me some approaches?
Working with non-standar pitches
capitan mission
myspace.com/capitanmission
http://soundcloud.com/capitan-mission
http://www.facebook.com/pages/Capitan-M ... 0374261493
use the csound add-on, with csound you can generate any pitch you wish
capitan mission
I need to learn how to use the csound add on, It seems a very powerful tool.caco wrote:use the csound add-on, with csound you can generate any pitch you wish
And what about the synthesis pack? I am searching add ons that work with any frequency.
CleverConQueso
There's a pitch shifter in the add on's you can modify to shift to non-standard tones. It uses the Vocoder objects, which you can also play with to make or modify pitches. Finally, there's a 'wave table' synth in the add on's that uses arrays to make wave forms. I've been playing around with these to create audio and they'll let you set your own pitches.
Users browsing this forum: No registered users and 412 guests
