Loop recorder with the piano roll
noise2sine
Unread post by noise2sine » 06 Aug 2011, 08:48
My request is to be able to record midi loops or midi sequence on time. I'm using two tracks. The first is a 4 bar midi loop with a simple beat used as a metronome and the second track is used for the takes.
- the problem i'm facing, is when i press rec on the piano roll, i can see that recording doesn't start from the begining of a bar even if i quantize the rec button to "bar".
- When i did this test, what i have recorded doesn't correspond to what is played. the initial pattern is just quavers (croches) on 4 bars and the recording are quavers but not recorded at the right place within the bar.
- Is there somewhere an existing patch close to what i want ?, i just want to start a recording at the beginning of a bar in order to rework easily the takes.
Cheers,
Unread post by nay-seven » 06 Aug 2011, 09:09
hello,
you'll check today but i think the piano roll has been improved in the new version .
noise2sine
Unread post by noise2sine » 07 Aug 2011, 09:50
Hello Nay,
I have just tested the super great new version and i made the same test as described above. It's better for sure but not perfect.After recording one bar filled with quavers, i have one semi quaver empty space at the begining of the recording. Therefore all the take is not accurate "barwise". I just need to edit a little bit to make it accurate. Do u think it will be fixed soon ?
Unread post by senso » 07 Aug 2011, 10:43
the accuracy of midi recording in usine seems to be good.
So maybe more a matter of patching, PianoRoll settings or setup/bloc size?
see the test patch http://www.sensomusic.com/forums/upload ... %20rec.pat
noise2sine
Unread post by noise2sine » 07 Aug 2011, 14:14
thanks, it works fine !
noise2sine
Unread post by noise2sine » 09 Aug 2011, 07:33
Is there any special trick for saving MIDI files when recorded in the piano roll ?? i have 4 bars recorded and i saved it. When i reopen it i have just the first beat of the first bar recorded ? Any trick there ?
Unread post by nay-seven » 09 Aug 2011, 10:19
can't reproduce this right now
can i have more details
you have this problem in pro version rc2?
you choose how many midifiles at first..?
noise2sine
Unread post by noise2sine » 09 Aug 2011, 13:33
Hello Nay,
i'm using Rc1 Pro Version.I'm using the patch you made "mustang midi guitar". I'm using the 16 midifile piano roll.
Unread post by nay-seven » 09 Aug 2011, 16:21
ok, will test , but RC4 is coming...;)
noise2sine
Unread post by noise2sine » 10 Aug 2011, 10:49
Hello Nay,
i have just tested the RC4 version and i'm facing the same problem. I have recorded 2 bars with the piano roll, then i have saved it and finally reopen the midi file which was previously saved: the notes don't have the same length ! . Right now saving a midi file will change its length.
What am i doing wrong ?
Unread post by nay-seven » 10 Aug 2011, 20:03
ok, I'll try again then
noise2sine
Unread post by noise2sine » 12 Aug 2011, 09:16
Just a little up ! :)
Unread post by nay-seven » 12 Aug 2011, 09:26
hello, a new version will be out today, i can't reproduce exactly the same problem than you, but first cut notes bug have been resolved, hope it will be ok for you too
noise2sine
Unread post by noise2sine » 12 Aug 2011, 09:32
thank u Nay ! but it's not only the first note that are cut but the whole midifile. In other words the save as function change the whole midi file.
Users browsing this forum: No registered users and 231 guests
