IanniX is a graphical open-source sequencer
iococoi
Unread post by iococoi » 11 Jun 2011, 17:23
hi all..
stumpled over this yesterday
IanniX is a graphical open-source sequencer, based on Iannis Xenakis works, for digital art. IanniX syncs via Open Sound Control (OSC) events and curves to your real-time environment.
http://www.iannix.org/en/
http://www.iannix.org/fr/
..strange thing but nice interface. didn't do too much testing though...
cheers,
io
r.erorr
Unread post by r.erorr » 28 Jun 2011, 23:00
How can you open it in USINE, because "Iannix alone makes no sounds and does not use audio directly". I tried to open some plugins unsuccessfully.
Unread post by nay-seven » 28 Jun 2011, 23:14
you can't open Iannix in Usine , but Iannix send OSC messages ( port = 2001 ) Usine can use
r.erorr
Unread post by r.erorr » 29 Jun 2011, 20:00
nay-seven wrote:you can't open Iannix in Usine , but Iannix send OSC messages ( port = 2001 ) Usine can use
this is what I receive from IanniX to USINE console: [1609381] OSC in from 127.0.0.1 : /cursor (fff)
But receive OSC module keep silent and send OSC can't send nothing to IanniX.
Unread post by nay-seven » 29 Jun 2011, 20:51
yes, just realize they change the send port in the last beta , it's now 57120 ( to be compatible with ableton)
and by default the Iannix receive port is 1234, but i never test the receive use
and things will be more easy with next Usine release too, with a new mode in the OSC receive module
r.erorr
Unread post by r.erorr » 28 Nov 2011, 05:42
Is it possible to receive Iannix messages with latest Usine version? I did all as described in wiki, but nothing happens
Unread post by nay-seven » 28 Nov 2011, 09:24
yes , works fine here :
but be aware that Iannix send a lot of OSC message
here a screenshot for a simple example if it can help
r.erorr
Unread post by r.erorr » 28 Nov 2011, 22:28
Unfortunately not, I don't know why my Usine can't receive any data from Iannix. Maybe there is need for some configuration on Iannix? hmmmmm...
Unread post by nay-seven » 28 Nov 2011, 22:45
nothing to change in Iannix..disable the firewall to check if the problem is not here
then add a simple circle and press play in Iannix, do you see the adress near the transport..? something like
osc://127.0.0.1:57120/cursor 2 0.186425 0.110551 -1.54291 -1.34719 0
Users browsing this forum: No registered users and 188 guests
