Hi Senso and community !
1) I'm still using usine 4.22d sometimes for Midi only, and I'd like to know if usine is running at 44100 khz by defaut when the NO AUDIO parameter is activated?
2) I'd like to know if there is anybody here able to create a script that allow to delay a data value by a number of samples?
Thanks a lot and congratulation for all the work on usine. I'm sure I will upgrade my usine to the latest version sonner or later. I also wish to see this great software on my macbook one day, I'm sure you are thinking about it and I encourage you to release it because I'm sure there is a lot of potential users using apple computer.
Cheers.
Moody.
Sampling rate when NO AUDIO activated?
mmmm, just testing the latest version...so, I've upgrade it !
When [no audio] is activated, Usine use an internal clock which is less precise than the ASIO clock and also more dependent of you system.
We can't answer directly to you question.
Try to make tests yourself to have an estimation of the time between two patch calculation (using the precise time counter module).
Then you will be able to delay data's by a certain amount, probably by steps of 256 samples.
Thanks for your answer.
So I think it's better to use Audio On without using audio in the signal path if I need a precise timing. I will make some test later. But it seems to use an internal clock of 44100 hz according to the sample rate module.
Users browsing this forum: No registered users and 423 guests
