Usine Free: No Modules in Browser
newuser
Unread post by newuser » 18 Dec 2010, 19:17
I'm trying out Usine, but there are no modules or anything else showing up in the Browser. I've downloaded and installed it twice, as well as tried to configure the directories manually.
Does the free version not include any modules?
Running Windows 7 pro 64-bit.
Unread post by nay-seven » 18 Dec 2010, 19:40
Hello and welcome
have you try to double click on the triangle in the browser..?
if yes, can you check the files are in your dir : files/modules...
Users browsing this forum: No registered users and 92 guests
