a lot of questions
i just begin with usine and it's a dream but (et oui,il y a toujours des but)
i have some question :
- the installation first, i don't find usine in "programme et fonctionnalites", and when i click on a WPK file windows says that usine is not installed propely....
-is it possible to put usine on automatically at statup i try with the run option of the dasboard module and the on initialization module but it's don't work....
-is it possibleto keep the minimization of the "entete" of the track at startup
-i have some problem with setup,
in midi input,i loose sometime one of the midi input, it was remplced by another one???,
in audio output i use the two mono input like that :
in1: in 1 L : fw 410 analog in 1 (i have the m-audio FW410 who works perfectly)
in 1 R: fw 410 analog in 1
in2: in 2 L : fw 410 anlog in 2
in 2 R : fw 410 analog in 2
is it right?
and sometimes it replace in 2 by in 1 so i loose the second input!!!!!!
- does exist the sama as stacked macro from reaktor?
-i have a problem with the mouse on fader, i create fader with a bitmap from 0 to 127, i when i moved the mouse the fader skip
a lot of value for example i must have 0,1,2,3,4,5 and i have 0,3,5,9,.....,it's a big problem for me, i modify "small icon tolerance" but it's the same.....
-i use mobius but the postion of the windows is not memorized by usine(i don't use dual windows...)
does somebody have the same problem?
so,i have another question but it's enought for the moment,
i hope you understand
thank you
laurent
is it right?
thank you
laurent
ZARBY PROD TV : http://www.youtube.com/watch?v=mhmIRUK_Rj4
ZARBYSPACE : http://www.myspace.com/zarby
first welcome zarby !
normal cause Usine don't install anything in your C: , it's a portable software, you decompres the zip et hop, that's all , about wkp files , right click on it and choose open with point to Usinemain.exe in the files dir- the installation first, i don't find usine in "programme et fonctionnalites", and when i click on a WPK file windows says that usine is not installed propely....
put this patch in you master insert patch ( double click where is the red circleis it possible to put usine on automatically at statup i try with the run option of the dasboard module and the on initialization module but it's don't work....
don't think so , but i've to check-is it possible to keep the minimization of the "entete" of the track at startup
if it's usb devices , it's a windows issue who change the id of usb dvices on startup-i have some problem with setup,
is it right?
gone to see what is a macro in reaktor , a kind of sub-patch you can reload or..?- does exist the sama as stacked macro from reaktor?
is it a bitmap you create..?if yes , check frame count in the edit layout window-i have a problem with the mouse on fader, i create fader with a bitmap from 0 to 127, i when i moved the mouse the fader skip
i've also moebius installed, gone to check-i use mobius but the postion of the windows is not memorized by usine(i don't use dual windows...)
OK
is it right?
for audio it's the firewire 410
it's a subpatch with other subpath in it and with an index you can choose the activ subpatch
i m going to try to make it, ithink it's possible with container
ye it's bitmap that i create and frame count is good i use a lot of of these things with reaktor
ok
thank you for you response
laurent
OK
is it right?
ok
laurent
about your midi devices you loose , you can try copperlan to solve this , here the tread :
http://www.sensomusic.com/forums/viewtopic.php?id=2381
about your firewire card, gone to ask to senso
about your fader, can you upload an example..?
about your FW in/out issue.
maybe a driver problem?
how can i upload an example of my fader (for the mouse problem)?
you can zip the files and use the uploader of this forum, then copy paste the link in your post
same process than for a picture, check this tips
i send it :
it's calling stached subpatch
the problem with the mouse is with the fader in side the container but
if you can help with router 1 N it must send a trigger to the selscted show
thank you
laurent
thank you
laurent
sorry but that's why i was talking about zip the files..., you have to put the pictures too...
if not i can't see yours faders ?
and you can also add the link directly in your post...
ok, sorry :
no more bmp files in your rar file....?
and use the add link button to post the link, works better..
ok i forgot the pictures but when i try to send another i've "Error: There is such file on the server. "
yes, cause you have to use a different name, gone to delete old ones anyway...
i hope it's good this time!!!!!!!!!!!!!!!!!
http://www.sensomusic.com/forums/upload ... ile=F1.rar
ok, there's some pictures missing , but i understand
in the edit layout window, active the touch hi precision button and play with the precision factor , will work
it's because your fader is really small ( for example if you use midi learn, this works , even now..) with the mouse it's difficult to have 127 step in a such little place..
i try with precision factor and theres allways the problem....
i give you the two picture of thefirst subpatch
mmm, really strange cause works fine here, are you sure you have change the parameters for each faders..?
if someone else can test...
i do that for all the fader and it's allways the but yo've remarked that they are in two containers???
yes, i've see , but there's no link between the container and the precision of a fader
here without touch hi precision button active , i note jumps as you said
with the touch hi precision on and a precision of 8 or 10, i can smoothly pass from120,121,122 and so..
that's why i ask if someone else can try ..
it's exactly the same fader that used on reaktor and i have no problem with it
on reaktor you can specifie the number of step of the mouse...
i've send your fader to senso, i know he also has reaktor , maybe he can give you an answer..
but if someone else want try...here just the fader in a patch
Usine has a different approach than Reaktor, especially the touch-screen management.
@zarby:
you'll not obtain the expected result with a vertical fader but you should try great encoders made by 23fx. Can be a source of inspiration?
http://www.sensomusic.com/download.php? ... s%2001.wkp
http://www.sensomusic.com/download.php? ... ER_A01.wkp
@zarby:
ok, no problem bacause my goal is to controle them with keyboard....
can you help me with another problemin this subpatch,
i try to controle the show of the container with the fader select,
it don't working good....
here is the link
http://www.sensomusic.com/forums/upload ... bpatch.rar
here is the link
so, if you want to use your keyboard , you can add 2 button on the fader and use key learn on it..?
for your patch : if i understand correctly , activate the audio flow in the dispatcher ( this way only the select out send 1 , others will be reset to 0 ) and use the visible inlet , not the show inlet of the container
btw, this kind of question are for the patching questions forum please
super cool, it's working
thank you
laurent
thank you
laurent
Users browsing this forum: No registered users and 176 guests
