Looking for demo VSTI
I'm working on a new demo set for Usine.
The goal is to build a complete workspace, which include some examples of patches we generally use on stage.
Actually, I have a small problem:
I don't have any VSTi (synth, drums, etc.) that I can include into the Usine package.
Is there any VST programmers on the forum that can give me the authorization to add their VSTi in the demo?
Of course, they can be them self as demo or restricted.
I will credit the generous donator on the patch it self. (link to the main page, etc...)
Thanks by advance.
Thanks by advance.
Vincent
Hi Olivier.
Yeah, one more good idea. You're just killing...
The best solution for all would be VSTi developers using Usine of course.
But if you obtain no answer, I can give you links of two or three good free synths, and one free drum, if I remember (tested in Usine). Just ask.
BTW, some Acousmodules I've tested just crash Usine. I would say "Nickel Crash"!...
Olivier - if you haven't already, ask at the developers forum at KVR for someone interested. I'm sure you'd get some positive response.
Most of Acousmodules work fine on my system.
I'm in contact with JM Duchenne, he's a master in surround.
But in fact I need simpler VSTi
Basic synth, drums synth, bass....
i'm the owner of a french forum about synthedit , there's about at least 10 users who devellop some good one ( KX77FREE , novaflash, bserrano ), gone to ask...no problem
first answer from b.serrano which is enthusiasm about your idea you can check his homepage and have a look on his work , he suggest you " artemis" but you can of course look other ones ....
http://bserrano.free.fr/Synths_Artemis.html
second answer :
you can also check novaflash works here
http://www.numerisson.com/novaflash/
he is ok to work on a light version of one of his synth?
except oxytocin ( same problem i've first with the vsti i send you to test (ck oscillo) )
i use microgram in Usine without problem ...
and about my vsti Multiball , of course i could be ok but i'm not sure it this kind of vsti your looking for...???
btw , have you find the time to have a look on it..?
thanks a lot,
I'll take a look.
For most people, Usine seems to be very abstract and I want to show in one demo set that it can be used in e more "conventional" way.
I'll take a look.
I've tried you vst. It's very fun to use but I'm looking for more "standard" stuff...and about my vsti Multiball , of course i could be ok but i'm not sure it this kind of vsti your looking for...???
Vincent
Hi Olivier.
Try the Istvan Kaldor's Dirt Bag, a kindov H?mm?nd B3, very interesting indeed.
You'll find on the same page the Dirt-E witch is an element of that VSTi to use as VST, the Dirty Leslie. I like it very much and use it with samples of a distorted Fender Jazz Master.
I like the Killerz of Novakill too. Very powerful synths, just killing.
All made with SynthEdit.
I thought that I've already post something about it, but I don't find it.
I think the following are more "standard". You mean... pop, jazzy, trance?Senso wrote:I'm looking for more "standard"
senso , a new one is waiting you on my forum ...
nice vst.
thanks for your help.
Hi Olivier,
You could freely use Abakos synth from
http://www.hercsmusicsystems.com/downloads/Abakos_2.zip
(I'm a KVR Forum moderator for hercsmusicsystems)
Cheers,
Cheers,
abakos is really a great plugin !!
nice gui and nice presets ! thanks for this
by the way i've see your other beta project Viktor
but this one can't open in Usine..what a pity..
[11:15:37] TpgVST Access violation at address 1487159A in module 'viktor_vst.dll'. Read of address 00000000
[11:15:37] Error:Internal
[11:16:24] TpgVST Access violation at address 1487159A in module 'viktor_vst.dll'. Read of address 00000000
[11:16:24] Error:Internal
It works perfectly with the new version (coming soon)
Please, you can include our free synths in future Usine releases.senso wrote:It works perfectly with the new version (coming soon)
Miquel.
strange , cause , always same error here :
[18:32:43] TpgVST Access violation at address 0D5F159A in module 'viktor_vst.dll'. Read of address 00000000
[18:32:43] Error:Internal
I'm confused, I was talking about abakos, not viktor...
How can you get viktor?
It's not available for download on the site.
Don't forget that Viktor is a beta.
h? h? , yes i've explore the site and found a link in the forum section...senso wrote:How can you get viktor?
http://www.hercsmusicsystems.com/vst.html
of course ,but was thinking that mahtazz could be interested by the info...senso wrote:Don't forget that Viktor is a beta.
and as say Vincent on my forum " a plugin who don't work in Usine is not a plugin.." ( joking mahtazz , no offense..)
No worries. I will check Vitkor beta in Usine 2.8
BTW, I'm not the plugin developer, only KVR Forum mod.
Cheers,
Miquel.
Cheers,
Miquel.
Users browsing this forum: No registered users and 435 guests
