VST parameters Randomizer
Unread post by senso » 14 Aug 2010, 17:41
It was an old request, now implemented.
The next version 5.25 beta6 will include a VST param's randomizer script fully integrated in the template engine and very easy to use.
See http://www.sensomusic.com/wiki/doku.php ... randomizor
Unread post by nay-seven » 14 Aug 2010, 18:14
Fantastic , we can now built new presets , bank directly in Usine !!
multiphone
Unread post by multiphone » 14 Aug 2010, 19:10
Very nice news !! Thanks.
HB
Lines / Points / Squares
http://www.hervebirolini.com/
Unread post by senso » 15 Aug 2010, 14:54
also added
-nb randomized (%)
-amount (%)
see http://www.sensomusic.com/wiki/doku.php ... randomizor
DriftZ
Unread post by DriftZ » 16 Aug 2010, 19:32
I find this a very nice addition, many thanks.
However I experience some problems with it, although the scripts correctly shows the names of the parameter you can select to be randomized, they are somewhere under another 'button' . I tested this with NI reaktor and NI maschine.
e.g. in maschine:
I set Macro A1 to be randomized, nothing happens
I set Macro B7 to be randomized, macro A1 (!) gets randomized.
Anybody else seen this ?
best,
Geert L.
Core2Duo-T7500, 3GB, Geforce 8600M GT, Echo Indigo DJx, WinXP
NI Reaktor, NI Maschine, APC40-Live Akai edition, VVVV, Usine
DriftZ
Unread post by DriftZ » 16 Aug 2010, 19:54
Some other observations:
-When I have 2 vsti's loaded (on different patches, on different tracks); insert vst randomizer on each, the first one stops working.(until i compile and reload it, but then the 2nd stops working)
-After this, 'auto patching' no longer works, e.g. add a module/click on an input of a module in patch #2 it shows up in patch #1 (!)
best,
Geert L.
Unread post by nay-seven » 16 Aug 2010, 19:57
i don't have this plugins but i suppose it's the same for many vsti
some manufacturers let's some parameters visible even if we can't use them
for example , i use kore free player and i can see many parameters who are not really used or at least that don't change anything to the sound...
what you can check ,:
if you also see this parameters in the control panel of the vsti
and if yes , when you move it , did this change anything..?
DriftZ
Unread post by DriftZ » 16 Aug 2010, 20:06
Hmm, I'm not sure it has to do with that because the randomizer script extract precisely all parameter names in the correct order.
But, ok i have tested it now with HeliosII that comes with usine. (new workspace, add heliosII vst and the randomizer)
Unselect ALL except 'Attack', click randomize, here then the beat setting of LFO2 gets randomized.
Select p-0, click randomize, NOW 'Attack' gets modified.
best,
Geert L.
Unread post by nay-seven » 16 Aug 2010, 22:06
yep, i confirm for the 2 instances , hope senso can fix that , something like target in other modules
about Helios II , I'm not sure it's a good example cause there's bad assignation ( test the 2 cutoff inlet for example )
DriftZ
Unread post by DriftZ » 17 Aug 2010, 19:10
Does anybody have/know any (free) vsti that works correctly with the randomizer?
(If i'm totally certain the problem is with the NI synths, I will contact them about it)
best,
Geert L.
Unread post by nay-seven » 17 Aug 2010, 21:29
here some I've test :
Arpe2006va
cosmo_se ( xoxos )
Neumixturtrautonium
Oatmeal
aerophone ( xoxos )
axons ( novaflash )
RMXL
kx-synth-x16( kxfree)
Adonis ( bserrano)
generally i begin with 60% for number / 50% of amount
be careful of course of some parameters, disable main volume ..
And be careful if you work with headphones...;-)
DriftZ
Unread post by DriftZ » 17 Aug 2010, 22:13
Nay-seven, and these worked ok for you?
I did a quick test with cosmo_se and RMXL, and in both tests, the parameters activated on the randomizer do not correspond with the randomized parameters on the vsti.
e.g. RMXL
randomizer: only 'Chrs-Rate-2' activated -> on the vsti : only ENV1 Decay gets randomized.
So it has to be the randomizer that does not work on my system for a reason....
It is hard to believe nobody else experiences this..
best,
Geert L.
Unread post by nay-seven » 17 Aug 2010, 22:15
oops , i must admit , i don't have check if each parameters correspond to the good ones
Unread post by nay-seven » 17 Aug 2010, 22:22
don't worry , senso will check this when he 'll be back i suppose
Unread post by senso » 17 Aug 2010, 22:24
A 'setTargetPatch' is missing in the Callback of the script. Will be corrected soon. If you cant wait just add the line:
SendInternalMsg('TARGet_PATCH','SENDER_PATCH');
After the line
3:begin
Unread post by 23fx23 » 17 Aug 2010, 22:37
i guess its: SendInternalMsg('SET_TARGET_PATCH','SENDER_PATCH');
DriftZ
Unread post by DriftZ » 17 Aug 2010, 22:41
hmm, I tried both Senso's and 23fx23's solutions, recompiled it but to no avail.
It's too late now, will investigate further, there's some other odd things going on (like the module in the patcher window resizes when I use the scrollbar on the parameter list.)
best,
Geert L.
Users browsing this forum: No registered users and 667 guests
