Flux tools from Ircam
Unread post by nay-seven » 27 Jul 2010, 10:00
a good point for ircam : ( my thought )
the new demo they propose will never expire , you can change parameters only for 30 mn , but then the audio is still processed
so , once you know the plugin a minimum , you can still use it in your tracks...
# Ircam Spat
# Ircam Trax
# Ircam Verb
http://www.fluxhome.com/products/Plug_ins/ircam_trax
Unread post by senso » 27 Jul 2010, 10:46
very good plugs, especially the SPAT.
multiphone
Unread post by multiphone » 27 Jul 2010, 22:05
Hello Nay !
Allways on the top !
I would like to take time and test that.
Thanks for the tweak.
Best.
H.
HB
Lines / Points / Squares
http://www.hervebirolini.com/
Unread post by nay-seven » 27 Jul 2010, 23:02
yep, they are really great tools
but really expensive and no cpu friendly...!!
so i suppose i will keep them for processing sounds more than live situation...;)
runagate
Unread post by runagate » 28 Jul 2010, 21:46
IRCAM is so great, it's sad to see them make their work proprietary and license it to one of the most absurdly overpriced VST developers
multiphone
Unread post by multiphone » 28 Jul 2010, 22:27
OMG !
1599 € for tree VST !!
Is not realy free ;-)
HB
Unread post by nay-seven » 29 Jul 2010, 10:05
I never say it's free Hervé..;-)
and that's why the fact you can set the parameters for 30 mn is a good thing..
then if you don't touch the plugin , it 's still process the sound...a good workaround to use them
Users browsing this forum: No registered users and 780 guests
