Flux tools from Ircam
a good point for ircam : ( my thought )
the new demo they propose will never expire , you can change parameters only for 30 mn , but then the audio is still processed
so , once you know the plugin a minimum , you can still use it in your tracks...
# Ircam Spat
# Ircam Trax
# Ircam Verb
http://www.fluxhome.com/products/Plug_ins/ircam_trax
# Ircam Spat
# Ircam Trax
# Ircam Verb
very good plugs, especially the SPAT.
multiphone
Hello Nay !
Allways on the top !
I would like to take time and test that.
Thanks for the tweak.
Best.
H.
Best.
H.
yep, they are really great tools
but really expensive and no cpu friendly...!!
so i suppose i will keep them for processing sounds more than live situation...
IRCAM is so great, it's sad to see them make their work proprietary and license it to one of the most absurdly overpriced VST developers
multiphone
OMG !
1599 € for tree VST !!
Is not realy free
Is not realy free
I never say it's free Hervé..
and that's why the fact you can set the parameters for 30 mn is a good thing..
then if you don't touch the plugin , it 's still process the sound...a good workaround to use them
Users browsing this forum: No registered users and 32 guests
