Usine in reaper
javanaiz
Unread post by javanaiz » 04 Apr 2010, 00:23
Hello dear usiners,
maybe some of you are using the usine vst version in Reaper.
I've been doing like in the manual
http://www.sensomusic.com/wiki/doku.php ... st_version
I Simply add 3 UsineVst plugins, one per track.
I got a midi item in reaper in my track 1
But I got this problem : this midi item is played throught track 1,2,3
instead of track one in usine (or reaper ?!)
anyone encounter rhe same problem ?
Txs
gurulogic
Unread post by gurulogic » 04 Apr 2010, 02:46
Yes, this a known issue in the Usine VST which hopefully will be fixed soon...?
javanaiz
Unread post by javanaiz » 05 Apr 2010, 20:29
Its a kind of weird !
cause if I play a "sample item" (.wav) instead of this "midi item"
the audio routing is all right
but ...
I got crackle and audio artefact
maybe an previous vst usine version is doing better ?!
Unread post by nay-seven » 05 Apr 2010, 23:17
hello
have you try to use only one instance of Usine vst and use several midi canal to route your tracks to usine...?
about crackles , i suppose you have test with different vst buffer size in usine..? ( setup /vst )
try also the last vst version..( 5.13 )
javanaiz
Unread post by javanaiz » 06 Apr 2010, 01:01
Hello N7 ;)
"have you try to use only one instance of Usine vst and use several midi canal to route your tracks to usine...?"
do you mean :
I only open a usine vst in my reaper track number one ?
then my "midi item" on "reaper track 2" will be routed to "usine track 2"
I tried but I didn't succed
I abled "map input to channel 2 in reaper on my track 2
but I aint got any "midi in" in usine ?
txs for the vst buffer :)
no crackle anymore now
Unread post by nay-seven » 06 Apr 2010, 07:28
here how i proceed :
in reaper , route all midi canal to 2 ( for track 2 ):
In Usine , filter canal 1 , for track 1, canal 2 for track 2 and so..works fine
and don't forget to set your audio out in Usine tracks too
javanaiz
Unread post by javanaiz » 08 Apr 2010, 00:05
Txs for your help Nay 7
It works this way :)
I also learn a lot about midi routing with your answer
In another hand the volume control is now controlled by "usine" for each track
I lose the volume automation of reaper for each track
maybe a easier implementation of "usine vst" in reaper (or other DAW)
would be nice for midi item (especially for newbies) like for audio (as in the manual)
++ j.
Users browsing this forum: No registered users and 479 guests
