Hi
is it possible to save subpatch and to have a open/close button
like patch
i think it was possible in the beta version 5 ?
thanks
save subpatch and open close button
L'orchestronique - foSolo
http://www.arbre-canapas.com/l-orchestr ... ideos.html
sorry, not sure to understand what you want to open/close...and in which mode..?
martignasse
Hi gercha1,
You'll find a 'Save sub patch as' in the file menu of the patch window, is it what you search for ?
There is two module to manage where and how a sub patch is visible.
- the popup module have open/close button and manage a popup stand alone window.
- the container module have 'Show' button and 'Visible' switch to make a sub patch visible or not.
With these two module and the 'where' combo box of a sub patch, you have a very powerful system.
Hope it help
Hope it help
thanks
i did'nt saw the file menu in the patch
i always looking for the global menu
gercha
gercha
The new "save sub patch as" option has gotten me a few times now. I end up saving the parent patch .Have to pay more attention when saving now...
Users browsing this forum: No registered users and 457 guests
