IB - items aren't staying where I put them!
Ben J
Unread post by Ben J » 22 Feb 2010, 04:31
Whenever I move tracks in IB and lock them down, go to Grid mode, then go back to IB, they always return to their normal positions, as if I had pressed "reorganize controls."
Is this a "bug" or does the user not have complete control over placement?
Unread post by nay-seven » 22 Feb 2010, 09:43
can't reproduce this....
can you try to make a new empty workspace , use ready made patchs from the usine tab of the browser , move them in the IB and see if it's the same..?
btw , this kind of problems must be in the patching question , please
Unread post by senso » 22 Feb 2010, 10:05
it's probably because you have activated the "automatic re-organize" option in IB layout?
Ben J
Unread post by Ben J » 23 Feb 2010, 00:34
nay-seven wrote:can you try to make a new empty workspace , use ready made patchs from the usine tab of the browser , move them in the IB and see if it's the same..?
This worked. I guess the patches won't behave unless they are saved. Thanks guys.
Unread post by 23fx23 » 23 Feb 2010, 00:42
yes i took me time to understand that lol, as well when playing with visibility setting invisible then back visible items wouldn't be in correct position, need to position them and save/reload the wksp.
