how to disconnect modul
randoom
Unread post by randoom » 25 Apr 2006, 22:15
hi there.
this software is very cool. thanks a lot.
question : how to disconnect modusl between them ?
shortcut key ?
Unread post by senso » 25 Apr 2006, 23:21
To disconnect wire, simply do the same operation than for connect.
Unread post by bsork » 24 Jan 2010, 00:02
...or select the wire by clicking the little square in the middel of it, and delete it like it was a module. A workaround if want to remove all connections to a module, is to cut'n'copy it (good ole' Ctrl-X, Ctrl-V :))
Users browsing this forum: No registered users and 462 guests
