Couple of guitar Rig 4 issues
MikeyJ
Unread post by MikeyJ » 01 Nov 2009, 08:00
Hi All,
Couple of probs:
1. Can't seem to get any Program info to appear in a List or Combo on a ctrl+Drag from Program on the VST.
2. When Usine first loads, the track will show the VST parameters in use for the current program. If I change the program using the VST interface the params don't change with it so now they are out of sync. Should they be switching with the program?
Bonus: when I DO see the correct params for the VST in the track, I sure wish I could right click on one and do a midi learn!
Thx,
Mike
Clearscreen
Unread post by Clearscreen » 02 Nov 2009, 02:47
which vst are you using? some don't pass the program or parameter info on to the host i think.
MikeyJ
Unread post by MikeyJ » 02 Nov 2009, 06:05
Thx for the reply.
Native Instruments Guitar Rig 4...
Mike
Unread post by nay-seven » 02 Nov 2009, 08:16
downloading the demo right now to check...
btw , you don't need to add ctrl now , a simple drag is enough on last versions..;-)
Unread post by nay-seven » 02 Nov 2009, 12:39
ok , so as all native instrument no way to use classic inlet program , but receive program change midi message
here a solution :
i've also add a mapper value , this way you can have your best preset quickly , there's also a list box , for visual feedback , but you have to edit it manually ...
create message is set to program change
make a midi learn on the knob " code 1 "
et voila..
Users browsing this forum: No registered users and 697 guests
