midi channel change
bmoussay
Unread post by bmoussay » 08 Jan 2007, 14:35
I've just uploaded a small patch that changes the midi channel of any midi message in the add ons.
Rgds,
B.
bmoussay
Unread post by bmoussay » 10 Jan 2007, 23:12
Just posted an updated version, the previous on didn't work well with note events.
Rgds,
B.
Unread post by bsork » 11 Jan 2007, 08:57
Hi bmoussay!
I've done the same thing by just sending the data straight from midi in to midi out, with a new channel fader connected to the "chan" input of the out module.
Have you tried that and experienced problems like missing or
stuck notes or something? Or that maybe some other non-channel-mode messages get corrupted?
Unread post by senso » 11 Jan 2007, 09:14
great idea bsork.
bmoussay
Unread post by bmoussay » 11 Jan 2007, 13:45
Hi bsork,
I'm gonna test your idea, seems to be great (anyway far more economic than mine ;-)...
Rgds,
B.
bmoussay
Unread post by bmoussay » 11 Jan 2007, 14:38
Just tested your idea Bsork.
It actually works perfectly, but only to send midi out of usine, because, first the midi out has no "out" outlet, so you can't send its data to a VSTi inside Usine for instance, and second, when you put the midi out in a subpatch, the channel inlet disappears, so you can't control it anymore.
So, to send midi with a channel change out of Usine your trick is really great, but use as a subpatch it unfortunately doesn't work.
Rgds,
B.
Unread post by senso » 11 Jan 2007, 16:28
your are right ben,
I will post an update that will solve definitively the problem (if it exists) with the channel filter option in the midi filter module.
soon.
Also, I think I have to change the midi philosophy under Usine. Not as efficient as the audio...
Users browsing this forum: Google Adsense [Bot] and 297 guests
