synthesis pack official thread
Let's talk about free additional packs
Unread post by nay-seven » 03 Jun 2010, 15:02
[center]Synthesis pack has been updated to 1.0[/center]
updates :
2 new Oscillator patches+ 1 big synthesizer patch :
OSC 3 : simple oscillator with 7 waveforms (sine, sawtooth, ramp, triangle, pulse, white noise, pink noise) and resonance parameter
OSC_Spectax32 :Spectral Oscillator with access to 32 harmonics
SYN_SYNTHAYAN patch example of synthesizer using this 2 new Oscillator
( don't except a classic one..;-) )
2 Oscillators:
4 modulation sources : 2 LFO, lines and sequencer route by a matrix
2 Effects : delay and Filter
Installation : Extract all the archive in your Usine /Files / Usine Library ( or better your "my library " folder )
check his wiki for more infos
note ! : This pack have been to update to 2.0
Unread post by bsork » 03 Jun 2010, 15:20
Something to play with! Thanks!
multiphone
Unread post by multiphone » 06 Jun 2010, 17:53
Thanks Nay !
Very nice and useful job.
Best
HB
Lines / Points / Squares
http://www.hervebirolini.com/
Unread post by 23fx23 » 06 Jun 2010, 18:00
woww coooool
i love the look!
Clearscreen
Unread post by Clearscreen » 07 Jun 2010, 01:51
Thanks for this - looks great!!
Unread post by nay-seven » 07 Jun 2010, 08:03
thanks guys , hope you'll have fun with
Gilles.D
Unread post by Gilles.D » 26 Oct 2010, 12:00
I am new to Usine : this tool seems to be perfect for my needs, and the oscillators found in the Synthesis pack are what I was looking for ! I have already built some kind of theremin driven by the mouse... Thanks to Olivier Sens, Nay Seven and every one involved in the making of Usine !!
But I have an issue installing the synthesis pack. I extracted the archive in my "Usine5.17FilesUsine Library" folder. When I first loaded the OSC patch, Usine told me
[center]"Can't find the VST D:vst_UsineSynthesis Pack VST_V0.9Oscillator (Mono).dll"[/center]
and then
[center]"Can't find the VST D:vst_Usine__SYNTHESOSC3.dll".[/center]
I found these files were in the subfolder
[center]"C:Program FilesUsine5.17FilesUsine LibrarySynthesis Pack v1.0 by Nay-SevenDLL".[/center]
I manually created the required folders on my D: drive, moved the files, rebooted Usine, reloaded the OSC patch, and it works fine.
But when I load the FX_reverb patch, Usine looks for "S:VstPluginsSynthesis Pack VST_V0.8bFDN_Reverb.dll". As I haven't any S: drive, I cannot create that folder and move the right .DLL inside it...
In conclusion, for all the patches contained in the synthesis pack, Usine seems to look for the .DLLs where they aren't meant to be.
Is my situation unique ? Is this a common bug ? Does anyone have any solution ? I have (not thoroughly) searched the Sensomusic and Nay Seven websites and found no information about that issue.
My configuration is :
Windows XP Pro SP3
Usine 5.17 Free, stand alone, installed in C:program files
Syntyhesis Pack 1.0
Matrix Pack 1.1
Old Dell Inspiron laptop. Pentium 3 (?) 1,4 GHz, 512 Mo RAM
Thanks again for making Usine and its additionnal packs and add-ons !!
Gilles.
PS : ça ne me gênera pas si vous répondez en français.
Unread post by nay-seven » 26 Oct 2010, 12:19
hello and welcome Gilles.d
i suppose it's a version problem, cant remember right now but in old version you have to put the dll files in your vst dir
so 2 solutions :
if you want keep your old version put all dll in your vst/vsti dir
or better : upgrade to latest version ,and just unpack the zip in you library , must work
btw glad you enjoy this pack, i've some upgrade to do soon , for the additive and spectra one..
about French , here it's the official forum and 80% of our users aren't French...but if needed , you can also use
audiaufanzine french forum
one precision : it's not in Usine/files/usine library
but in your library ( if you don't have create one yet you can also use Usine/files/demo dir for example)
but could be any dir outside Usine ( better to manage updates ) just enter the path in the global setup/interface
i 'm gone to be more precise in the how to install .txt, sorry
waolelaid
Unread post by waolelaid » 26 Oct 2010, 16:21
hello Nay how do i do to download this new synthesis pack i don't find the link
excuse me but i'm a bit destabilized my new config is dead in fact it's the motherboard
so i'm annoyed but fortunately it's still under warranty but i don't understand why it happens
it has only six months i'm disgusting all i touch goes wrong
good evening
in later :/
Friedrich Nietzsche
Unread post by nay-seven » 26 Oct 2010, 16:48
sorry for you waolebeau , always a bad moment..
there's no "new " pack i don't have upload it yet..
if you 're looking for the old version , they 're always at the same place :
http://www.sensomusic.com/download/
waolelaid
Unread post by waolelaid » 26 Oct 2010, 18:12
hello Nay I made a confusion i didn't remember that it was the same version
excuse me don't want to annoy you
thanx
Friedrich Nietzsche
Gilles.D
Unread post by Gilles.D » 29 Oct 2010, 14:45
Thank you Nay-Seven,
With the 5.25i version, the Synthesis pack works fine.
Document02
Unread post by Document02 » 16 Jan 2011, 17:51
Gilles.D wrote:[center]"Can't find the VST D:vst_UsineSynthesis Pack VST_V0.9Oscillator (Mono).dll"[/center]
and then
Actually ran into the same problem on the newest version of Usine & synth pack (downloaded a couple of day ago). Finally solved it by moving all DLLs in Usine's filesdemovst folder.
This is not a big issue, but should be addressed in the installation manual.
Unread post by nay-seven » 16 Jan 2011, 18:31
ok, will check ...
Unread post by nay-seven » 16 Jan 2011, 18:53
checked with 5.25k
install a fresh version of Usine, create a new folder "my library" outside Usine folder /put all the pack inside
works fine...?
Document02
Unread post by Document02 » 16 Jan 2011, 19:28
The install is fresh and new (actually 3 days old).
Basic issue is that the VSTs in the pack are not scanned by Usine.
They just need to be put wherever convenient & scanned (Usine Demo folder already contains some VSTs that I guess are useful, so I just dumped everything there and it works fine).
I think it just needs an additional line in the installation manual "copy the content of the DLL folder in your Usine VST folder (default is demo/VST)" , nothing more.
Unread post by nay-seven » 16 Jan 2011, 20:35
no, all the pack can be in your personal library ( you have set it in the global setup/interface ) , must works
joffo78
Unread post by joffo78 » 15 Mar 2011, 06:55
Well done nay ! Reaktor is dead.
Unread post by nay-seven » 15 Mar 2011, 09:01
hé hé , thanks joffo, but this pack is really far from reaktor...:D
ErotiCore SteNch
Unread post by ErotiCore SteNch » 14 Aug 2011, 22:07
this i will get alot of use with,been meaning to check out synthedit or synthmaker but now you need is usine:)
im sooo glad i decided to get usine,and when i get my touchscreen overlay for my ekstra 22 inch lcd monitor it will be awesome
Asensory
Unread post by Asensory » 11 Jan 2012, 05:10
I am having a problem with installation. Pardon my lack of experience, I am just beginning to explore the Usine demo and decided to try out the Synthesis pack at the same time. The documentation says to extract-all to Usine Library (set in global setup/interface/patch library). I simply do not see anything resembling ay of those directories in my Using folder. I extracted the files in the "Usine Library" and left the folder name as is, but the patches will not load (despite being visible in the browser). Any help...?
Unread post by nay-seven » 11 Jan 2012, 07:53
hello and welcome,
i've test on a fresh install and it works
so,2 way here :
Create a dir wherever you want and give the path in the global setup/interface/patch library ( this solution is better to manage Usine updates) and you'll see the contents in the library tab of the browser.
extract all the zip here
Or extract all the zip to the Usine library, something like
D:Usine Pro StandAlone 5.70 035Usine LibrarySynthesis Pack v2.0 by Nay-Seven
you must see something like this :
