Vst configuration files
All about the Usine Manuals & Wiki
skraninger
Unread post by skraninger » 21 Apr 2016, 21:52
Is there any documentation on how the Vst configuration files are used?
Unread post by nay-seven » 21 Apr 2016, 22:45
What kind of info's are you looking for ?
these files can be read with a basic text editor if needed
they are created when you scan your plugins folder, then Usine know which ones are ok, some can be corrupted or create errors and so...
skraninger
Unread post by skraninger » 21 Apr 2016, 23:28
I was just wondering if the content of the files had any function. One of the Vsts I am using complains of a parameter problem (but still works).
Users browsing this forum: No registered users and 5 guests
