Handbook of Usine modules, patch and libraries in pdf ?
Could it be possible to create an useful handbook of Usine modules in pdf format?. With bookmarks and with a quick index?
I think that a very rudimentary pdf with every module (no indexed, no bookmark) could be the first step. That way it would be easy to correct styles, etc. This basic pdf could be done using the docuwiki I believe.
what do you all think?.
yes it's a good idea.
Actually I don't know how to proceed but, I'll think about it.
Please let me know about it.
Hi!
As a proof of concept, I finally managed to create an all-in-one CHM file containing all of the usine manuals!
Well done Floego , really useful !
can you create this for each language and what is the total size of the pdf..?
Yes, I think it is possible for each language. And for the english one, it is about 30 MBytes in size, mostly for the jpg images.
Sorry,
i cannot open this file : i only get index, but nothing else.
Something wrong with the link ?
Strange , I've test it , works fine here, what do you use to read it..?
by default the help reader of windows is C:windows/HH.exe
Well, that perfectly works on my laptop,
but doesnt work on my PC (specialy made for music...) : i dont understand...
Ill see.
EDIT : big thanks to floego !
Ill see.
Well,
i can open it but i have to open it on the link.
If i save the file on computer, its impossible to read : have you got the same problem please ?
have you try the tips I've give you..?
try this:
right click on the file and select open
if windows say he can't open the file
select let me choose the appz to open and look for HH.exe in your c:/windows
must work
try this:
must work
What windows version do you have, xp, vista or seven?
when you said it can't be readed, it means it can't be opened too?
ANTE SCRIPTUM : now that works...
____________________________________________________________________________________
Well,
i have Windows 7 (64 bits).
I have extracted the file, then i have saved it. When i click, a window is open.
But i have only index : if i click on a title, i get this message : "Soft cannot open this page".
I follow your advice, Nayseven, but noway. Furthermore, my impression is that HH.exe is used by default.
The stranger fact is i can read this file by clicking directly the link !
POST SCRIPTUM : ok, i have made another thing = open by the link, and copy the temporar file. NOW THAT WORKS PERFECTLY !
(but strange...)
Well,
(but strange...)
In windows 7, there's a security control that maybe is blocking you to access the contents of the chm file.
From this site: http://techdows.com/2011/08/how-to-view ... ows-7.html
you could try the #1 option.
The #2 option is more or less harmless but requires you to go to the windows prompt etc.
I strongly advise you not to try the #3 option unless you really know what are you doing.
back to the office after a summer break.
great job floego+++++
Thanks and welcome back senso
is there a pdf version of the modules ref and manual that is cross platform or pdf. I cant download this one for my mac.
not easy cause the wiki is always updated , but we know we have to find a solution .
Hi i'm always late but where is the link to this file ?
i don't find it
thanx
i don't find it
thanx
Friedrich Nietzsche
Friedrich Nietzsche
Actually, there's no file to download, the old first try from Floego has been suppressed, was out dated, we still have to find a solution
hi again i just asked this question because this old post was reopen
i understand that it's difficult to do this kind of file as Usine is in perpetual changes
maybe another time
thanx
maybe another time
thanx
Friedrich Nietzsche
Friedrich Nietzsche
shreeswifty
- New member
is there a printable usine manual anywhere?
get a 404
w.
get a 404
w.
ho, it's really an old post !
now Usine 3 manual are here : http://www.sensomusic.org/manual/
you can also access each of the chapters with the ? in left menu
Maybe if I get some time soon I could extract the web into PDF.
Wasn't there an updated manual that was in progress too?
I could help if it is needed to complete.
-s
-s
I would really like to see a pdf version if possible...
imodularsynth
About manuals : there is a broken link on the website.
The link to API documentation on this page http://www.sensomusic.org/manual/en/sdk leads nowhere
Benoit
Benoit
Link solved, thanks for feedback
