Handbook of Usine modules, patch and libraries in pdf ?
All about the Usine Manuals & Wiki
Floego
Unread post by Floego » 11 Jul 2010, 02:08
Could it be possible to create an useful handbook of Usine modules in pdf format?. With bookmarks and with a quick index?
I think that a very rudimentary pdf with every module (no indexed, no bookmark) could be the first step. That way it would be easy to correct styles, etc. This basic pdf could be done using the docuwiki I believe.
what do you all think?.
Unread post by senso » 11 Jul 2010, 13:02
yes it's a good idea.
Actually I don't know how to proceed but, I'll think about it.
Floego
Unread post by Floego » 11 Jul 2010, 14:21
:cool:
Please let me know about it.
Floego
Unread post by Floego » 22 Aug 2011, 19:08
Hi!
As a proof of concept, I finally managed to create an all-in-one CHM file containing all of the usine manuals! :)
Unread post by nay-seven » 22 Aug 2011, 21:38
Well done Floego , really useful !
can you create this for each language and what is the total size of the pdf..?
Floego
Unread post by Floego » 23 Aug 2011, 00:19
Yes, I think it is possible for each language. And for the english one, it is about 30 MBytes in size, mostly for the jpg images.
Unread post by nay-seven » 23 Aug 2011, 17:13
So here it is :
English Version
Thanks to Floego
djPESSOA
Unread post by djPESSOA » 23 Aug 2011, 18:27
Sorry,
i cannot open this file : i only get index, but nothing else.
Something wrong with the link ?
I have no identity,
I have no age,
I am Pessoa.
http://partenulle.blogspot.fr/
Unread post by nay-seven » 23 Aug 2011, 18:47
Strange , I've test it , works fine here, what do you use to read it..?
by default the help reader of windows is C:windows/HH.exe
djPESSOA
Unread post by djPESSOA » 23 Aug 2011, 19:13
Well, that perfectly works on my laptop,
but doesnt work on my PC (specialy made for music...) : i dont understand...
Ill see.
EDIT : big thanks to floego !
I have no identity,
I have no age,
I am Pessoa.
djPESSOA
Unread post by djPESSOA » 24 Aug 2011, 16:25
Well,
i can open it but i have to open it on the link.
If i save the file on computer, its impossible to read : have you got the same problem please ?
I have no identity,
I have no age,
I am Pessoa.
Unread post by nay-seven » 24 Aug 2011, 16:42
have you try the tips I've give you..?
try this:
right click on the file and select open
if windows say he can't open the file
select let me choose the appz to open and look for HH.exe in your c:/windows
must work
Floego
Unread post by Floego » 24 Aug 2011, 21:09
What windows version do you have, xp, vista or seven?
when you said it can't be readed, it means it can't be opened too? :)
djPESSOA
Unread post by djPESSOA » 25 Aug 2011, 16:24
ANTE SCRIPTUM : now that works...
____________________________________________________________________________________
Well,
i have Windows 7 (64 bits).
I have extracted the file, then i have saved it. When i click, a window is open.
But i have only index : if i click on a title, i get this message : "Soft cannot open this page".
I follow your advice, Nayseven, but noway. Furthermore, my impression is that HH.exe is used by default.
The stranger fact is i can read this file by clicking directly the link !
POST SCRIPTUM : ok, i have made another thing = open by the link, and copy the temporar file. NOW THAT WORKS PERFECTLY ! :)
(but strange...)
I have no identity,
I have no age,
I am Pessoa.
Floego
Unread post by Floego » 25 Aug 2011, 16:42
In windows 7, there's a security control that maybe is blocking you to access the contents of the chm file.
From this site: http://techdows.com/2011/08/how-to-view ... ows-7.html
you could try the #1 option.
The #2 option is more or less harmless but requires you to go to the windows prompt etc.
I strongly advise you not to try the #3 option unless you really know what are you doing.
Unread post by senso » 31 Aug 2011, 09:52
back to the office after a summer break.
great job floego+++++
Floego
Unread post by Floego » 31 Aug 2011, 23:54
Thanks and welcome back senso :)
seamus
Unread post by seamus » 01 Jun 2012, 23:04
is there a pdf version of the modules ref and manual that is cross platform or pdf. I cant download this one for my mac.
Unread post by nay-seven » 01 Jun 2012, 23:48
not easy cause the wiki is always updated , but we know we have to find a solution .
waolelaid
Unread post by waolelaid » 02 Jun 2012, 04:05
Hi i'm always late but where is the link to this file ?
i don't find it
thanx
Friedrich Nietzsche
Unread post by nay-seven » 02 Jun 2012, 09:24
Actually, there's no file to download, the old first try from Floego has been suppressed, was out dated, we still have to find a solution
waolelaid
Unread post by waolelaid » 02 Jun 2012, 19:59
hi again i just asked this question because this old post was reopen
i understand that it's difficult to do this kind of file as Usine is in perpetual changes
maybe another time
thanx
Friedrich Nietzsche
shreeswifty
Unread post by shreeswifty » 20 Jun 2014, 16:56
is there a printable usine manual anywhere?
Unread post by nay-seven » 20 Jun 2014, 17:13
welcome shreeswifty,
yes, you'll find 2 manuals on the download page
planktone
Unread post by planktone » 29 Jun 2017, 17:36
get a 404 :-(
w.
http://www.planktone.be
I7, Windows 10
RME, MOTU
REAPER, VEGAS, LUCI
Unread post by nay-seven » 29 Jun 2017, 19:03
ho, it's really an old post ! ;-)
now Usine 3 manual are here : http://www.sensomusic.org/manual/
you can also access each of the chapters with the ? in left menu
sephult
Unread post by sephult » 30 Jun 2017, 12:52
Maybe if I get some time soon I could extract the web into PDF.
Wasn't there an updated manual that was in progress too?
I could help if it is needed to complete.
-s
osha
Unread post by osha » 22 Sep 2017, 23:16
I would really like to see a pdf version if possible...
imodularsynth
Unread post by imodularsynth » 28 Apr 2018, 07:12
About manuals : there is a broken link on the website.
The link to API documentation on this page http://www.sensomusic.org/manual/en/sdk leads nowhere
Benoit
Unread post by nay-seven » 29 Apr 2018, 18:41
Link solved, thanks for feedback
Users browsing this forum: No registered users and 173 guests
