addons wiki page
the first step is to create the page:
replace here my_addon by the name of your's and copy /paste in your browser
http://www.sensomusic.com/wiki/doku.php ... s:my_addon
you'll find :this page don't exist
use the create this page button
second step could be to go on existing addon page like this one :
http://www.sensomusic.com/wiki/doku.php ... ches:u-pad
use the edit button, copy paste what you 'll see and adapt it to your page
don't also hesitate to check :
http://www.sensomusic.com/wiki/doku.php?id=wiki:syntax
http://www.sensomusic.com/wiki/doku.php ... playground
and ask if any questions...
I will do this asap. Just doing some testing to make sure all is well. Is the uploader used to upload extra images? and is there a standard url or location on the wiki to access all the addons with a wiki page?
no, you have to use the add images and other files button in the wiki edit page
the standard url is the one i've give you, this way your addon will be with others patches :
http://www.sensomusic.com/wiki/doku.php ... es:patches
in, fact an other better way to find the good address is to name correctly your patch , then click on the ? inside and you'll be directly send to the wiki page ( important for others users )
sorry it's a bit confused..
i suppose I've to add a tips page for this..
Thanks for the info. yes a tips page is a good idea.
I've created one , just have a look and tell me what you think about ( as an "old " newbie..
