Page 1 of 1
Enhanced Player audio with template
Posted: 31 Aug 2025, 15:24
by joffo78
Here is an audio player optimized for theater and radio projects, but not only.
This patch, which can be added to your templates, offers a better experience for playing your audio files than the standard player.
- Playback and stop are triggered by a switch, which facilitates automation.
- The loop function is a separate mode, which allows you to trigger or stop playback without deactivating this mode.
- Another loop mode (marker loop) allows you to specify multiple loop points. When this mode is activated, a “release” button appears, which allows you to exit the loop smoothly.
- A pause function is available.
- A fade-in start and fade-out stop are possible.
- All player settings (pitch, gain, in, out, loop mode, etc.) are stored individually for each file on the list.
- From a pop-up menu, you can access the total file time as well as the elapsed time and remaining time expressed in h, m, s.
- Also from the pop-up menu, you have a vinyl-style start and stop effect (gadget) with adjustable duration and start or end pitch.
Have fun!
Re: Enhanced Player audio with template
Posted: 31 Aug 2025, 15:25
by joffo78
Have fun!
playertheatre iml template.zip
Posted: 01 Sep 2025, 15:34
by cmodica
Wahou ! Wonderful player and it is very useful.
Thank you very much to share this tool.
The same with a sampler recorder should be fantastic.
Have a nice day.
Posted: 02 Sep 2025, 10:43
by damstraversaz
that's really great, thanks a lot !
Posted: 02 Sep 2025, 11:27
by joffo78
Thanhk for your feedback !
Posted: 02 Sep 2025, 11:28
by joffo78
cmodica wrote: ↑01 Sep 2025, 15:34
Have a nice day.
I think you ve just to replace the module
Posted: 02 Sep 2025, 14:23
by rlgsbt
Nice ! thanks
Posted: 03 Sep 2025, 09:21
by cmodica
joffo78 wrote: ↑02 Sep 2025, 11:28
Have a nice day.
Yes, i will try as soon as i can.
sometimes, when i replace a module, some connections are broken ...
I will tell you.
Thank you very much
Posted: 05 Sep 2025, 23:14
by oli_lab
Great job !
I'm sure now that global arrays have no secret for you !
definitely will steal the "release" concept for some live improv situation.
here's a method to set, save and retrieve the markers as text files (.mkrs) in the same folder as the wave file.
save markers in text files.pat
enjoy !
Posted: 07 Sep 2025, 18:16
by oli_lab
I merged the release ideas with the saving of markers as text files thingo and I published a new addon !
