Rhythmicon, sample based
halbius
Unread post by halbius » 25 Oct 2018, 09:31
as one of my first steps in patching I tried to realize Henri Cowell's and Leon Theremin's
Rhythmicon
This version is sample based, because i wanted to use the grain sampler options.
You can use the keys c3 to d#4 to play the different samples.
Pitch wheel gives pitch glides, while the keys c1 to b2 change the overall harmonic key. C2 is here the center key, so you can shift it up and down 1 octave.
Of course the tempo syncs to the master tempo.
http://www.sensomusic.org/forums/uploads.php?file=Rhytmicon-Sampler.zip
If there is some time left, I will try another version which gives just midi out, so you can use other synths for creating sounds.
Any tips and suggestions are welcome:)
Unread post by nay-seven » 25 Oct 2018, 11:31
fun patch,
for info, i've edit your post cause your link was not working.
Some suggestions:
- edit the precisions of some faders/knobs , ex with pan spread, and random one, x.xx is maybe enough and take less place?
- you can also maybe edit start max value, cause start à 50% don't give sounds ?
finally if you want this patch as an Add-on and downloadable directly fromUsine, you need to use this page
