Pitch Shifter
Unread post by senso » 04 Jul 2007, 18:12
A simple pitch shifter made with Usine.
You can adjust the latency to adapt the audio quality to your purpose.
A built in 24db/oct audio filter can help you to improve the result.
Unread post by bsork » 06 Jul 2007, 08:15
I messed around with this patch yesterday, and I must say I'm impressed with what Olivier has done. It's not a simple patch (how could a pitch shifter be simple?) but it's also far from complicated, so if you - like me - fancy harmonizing with with artifacts; download now!
Unread post by senso » 06 Jul 2007, 08:46
I's simple to make a pitch shifter: tale a delay line an change the delay with a ramp, a saw tooth (up to pitch dwn & respectively).
To avoid audio clicks, take 2 delay lines above, with a cross fade.
