Page 1 of 1
Posted: 03 Feb 2015, 14:49
by sephult
What is the best method for handling external .png and other files related to an add-on?
Resources attached to some of my patches has been a question for some time, and I was hoping to get some clarity on how to handle and if they would upload and download properly.
I was also curious on how the in-application download would handle these. Do the .png become compiled within a .pat file?
I just recently had some files not open their .png correctly so I am almost led to believe they do not.
Maybe the best way is to create a directory within the resources folder of Usine as a reference and add the files onto a wiki?
Just some curiosities and questions.
-S
Posted: 04 Feb 2015, 12:53
by drakh
export patch/rack/workspace should put all needed external files (wav, png) with your exported work with correct paths, then just zip it and upload.
