Page 1 of 1
Posted: 03 Sep 2014, 14:38
by gercha1
HI
A PATCH TO CONNECT DIFFERENTS DANCEPAD LIKE THIS
http://www.diytrade.com/china/pd/3633112/USB_dance_pad.html
ONLY WITH USINE WITH HID MODULE
IN THE PATCH YOU SHOULD CHOOSE THE NUMBER OF THE DEVICE WITH THE FADER
YOU CAN CONNECT 4 MATS
THE NUMBER BUTTON OF EACH MAT ARE CLASSED LIKE THIS
9 10
5 4 3
6 2
7 8 1
THEN ALL THE 10 BUTTONS OF THE MAT APPEARS IN THE BINDS
FOR EXAMPLE FOR THE FIRST BUTTON OF THE FIRST MAT IT'S NAME "TAPIS1B1"
9 IS "SELECTED"
10 IS "START"
THE PATCH
http://www.sensomusic.com/forums/upload ... HID.device
EXAMPLE OF USE WITH CHILDS
dromoscope.fr/?p=205
GERCHA
Posted: 03 Sep 2014, 21:00
by waolelaid
Hi gercha1 thanx for the patch , you already give me one for usine 5.80b
which work with your dancepad in the first video i've the same that you have
but the only problem for me is that there is no driver so how can it be recognized
as a HID device i dare not install it because i don't understand how it could be
recognized
and congrats it must be very funny and interesting for the children
best :)
Posted: 03 Sep 2014, 22:32
by gercha1
hi
you don't need any drivers,
just plug the mat in usb before loading Usine
then in the patch, change the fader to find the device number of the mat
try with 0 , then 1 then 2.... walk on the mat
when the array move, the mat is connected
you find the device number !
be carreful always plug the mat in the same usb port,
and save the patch
it's "bricolage" but it works for me
have fun
gercha
Posted: 04 Sep 2014, 06:57
by waolelaid
Hi gercha1 and thank you for the explanations
i'll try it as soon as possible i must watch if i have an USB port free
on my computer
wish you a good day
Best :)
