Page 1 of 1
Posted: 24 Dec 2011, 05:17
by CleverConQueso
Folks-
I'm trying to knock-off BeatBurner as an exercise. So far I've come up with this.
- HERE -
http://www.sensomusic.com/forums/upload ... LICRRR.zip
A couple features -
Automatic slice calculation based upon the number of markers you want.
Envelope followers add to the base Wet/Dry value for effects with an inverse setting to turn the effect off as the level goes up.
CCQ-DuckingDelay inline with the effect circuit.
Use your keyboard to feed a pitch to the vocoder circuit.
Much appreciation for the many Usine patches from which I've borrowed or stolen.
Also, thanks to KVR for pointing me in the right direction.
http://www.kvraudio.com/forum/viewtopic ... beatburner
I'd like to post it back to KVR as a VSTi after I get some input.
- CCQ -
