Page 1 of 1
Posted: 15 Aug 2011, 19:23
by ErotiCore SteNch
i just downloadet and installed the synthesis add-on
but get some error messages something like cant find vst--name--
im running the latest version of usine pro 5,7
Posted: 15 Aug 2011, 19:49
by nay-seven
have you read the install.txt and put all the folder in your personal library..?
Posted: 16 Aug 2011, 12:10
by ErotiCore SteNch
yes i have extracted the file into usine library
Posted: 16 Aug 2011, 12:29
by nay-seven
as the install.txt say you need to put all the folder in your personal library, not the Usine one( and it will be easier to manage Usine update later)
Posted: 16 Aug 2011, 15:09
by ErotiCore SteNch
ok
i tried creating a my personal library folder,but that wont show up in the browser
so how do i set a personal library?:/
Posted: 16 Aug 2011, 15:17
by nay-seven
you create a folder, then in your global setup/interface you give the path of this folder as patch library
you can also read this Tip
Posted: 16 Aug 2011, 15:20
by ErotiCore SteNch
ahh ok thanks got it now
