Set all VST parameters with only one fader and one selector.
Unread post by senso » 17 Mar 2010, 21:12
Set all Vst params (5 Ko)
by senso Posted on 2010-03-17 21:09:45
You select which parameter you want in a combobox and you modify it with a fader.
It is also a simple example of IML in a script.
Very simple to use and can be easily modified to any VST.
La Tenaille
Unread post by La Tenaille » 17 Mar 2010, 21:51
shit... it works !
and I've changed the VST... and it works
and changed the fader for a switch... still works !
that's magic for me, just the opposit of my own weird patches because they hardly ever work :/
Thanks, usefull for me
Unread post by senso » 17 Mar 2010, 21:56
the IML is very powerfull and especially if we use it with a script...
gurulogic
Unread post by gurulogic » 17 Mar 2010, 22:32
This is just about the best thing ever! (Move over "Automap"!) Ok, so I totally need to learn the IML and scripting because it seems I am missing half of Usine...
Is there any way to get the parameters from a specific VST into a list without having input each parameter by hand?
edit:
I would also like to be able to use this globally over all Usine, not just within the current patch, or else be able to set track and line...? I also have great uses for this to controll Usine interface items also....?
(Edit: I have just realized controlling Usine interface items with this script is the same as for a VST, easy! Also easy is setting the track and the line for the script but a control inlet for track and line, or global option would be better...hello "Parameter Linking"! )
Ok, which way to the Usine IML / Scripting classroom?
(Edit: yes, I have found the scripting guides and tutorial and IML guides but...ouch, my poor head does not think like this!)
gurulogic
Unread post by gurulogic » 18 Mar 2010, 01:01
Sorry I'm getting a little obsessed now...
Shouldn't it be possible to touch a control on a VST and have the parameter name received by Usine as text?
I am thinking of being able to populate the combobox in this patch by simply touching the VST UI controls that I would want to populate the combobox with...
Would it also be possible to use a script like this in reverse, for example to get a parameter value?
Clearscreen
Unread post by Clearscreen » 18 Mar 2010, 02:04
WOW - this is pretty cool! Just need an easy way to get vst parameter names - symptohm might be a little difficult to deal with otherwise!! :)
Clearscreen
Unread post by Clearscreen » 18 Mar 2010, 06:19
For those that haven't noticed, you can run several instances of this script to control more than one selected item at a time...
And for those that have Reaktor Spark, here's the parameter list...
MC 1:MC 1
MC 1:x
MC 1:Ampl
MC 1:Drive
MC 1:Dest 1.1
MC 1:Dest 1.2
MC 2:MC 2
MC 2:Cutoff
MC 2:Reson
MC 2:x
MC 2:Dest 2.2
MC 2:Dest 2.1
MC 3:x
MC 3:MC 3
MC 3:Dest 3.1
MC 3:Dest 3.1
MC 3:- FB +
MC 3:Cab Mix
Mod Envelope:A
Mod Envelope:D1
Mod Envelope:R
Mod Envelope:D2
Mod Envelope:B
Mod En..Sustain
Mod En..Att. Vel
Mod E..Lvl. Vel
Mod E..Time Sc.
Mod E..Lvl. Sc.
Mod En..- Cut +
Mod En..- Drv +
Mod Env..Mixer
Mod En..- Del +
Mod Env..FB Osc
Mod Env Amo..RM
Mod En..FB Filt
Mod Env..- PW +
Generator..LP 2
Generator..BP 2
Generator..LP 4
Generator..BP 4
Generator..HP 4
Generat..Shaper
Generator..HP 2
Generator..Sine
Gener..Del + FS
Generato..Pulse
Generato..Track
Unread post by senso » 18 Mar 2010, 10:33
gurulogic wrote:Sorry I'm getting a little obsessed now...
Not really in the general case.
I can get all the parameters in a list but in most of vst its a nonsense because this list often huge and totally useless. see the list bellow...
The thing to do is to create a 'VstMap' file for all the vst,an hard job and not for me...
But in the next release, the parameter list will be exported as text file in the folder /temp/ for an easier editing.
yes, already integrated in the actual script. The fader position is updated according the vst param value.
Code: Select all
DRUMATIC list
p-0
p-1
p-2
p-3
p-4
p-5
p-6
p-7
p-8
p-9
p-10
p-11
p-12
p-13
p-14
p-15
p-16
p-17
p-18
p-19
p-20
p-21
p-22
p-23
p-24
p-25
p-26
p-27
p-28
p-29
p-30
p-31
p-32
p-33
p-34
p-35
p-36
p-37
p-38
p-39
p-40
p-41
p-42
p-43
p-44
p-45
p-46
p-47
p-48
p-49
p-50
p-51
p-52
p-53
p-54
p-55
p-56
p-57
p-58
p-59
p-60
p-61
p-62
BD: Amplifier Pan
BD: Amplifier Tone / Noise
BD: Amplifier Volume
BD: FX Amount
BD: FX Filter Cutoff
BD: FX Filter Resonance
BD: FX Filter Type
BD: FX Filter Type
BD: FX Filter Type
BD: FX Filter Type
BD: FX Filter Type
BD: FX Noise
BD: FX Tone
BD: FX Type
BD: Noise Amp Env Speed
BD: Noise Filter Cutoff
BD: Noise Filter Resonance
BD: Noise Filter Type
BD: Noise Restart
BD: Osc Type
BD: Tone Amp Env Hit
BD: Tone Amp Env Precise
BD: Tone Amp Env Speed
BD: Tone Mod Env Depth
BD: Tone Mod Env Speed
BD: Tone Pitch
CP: Amplifier Pan
CP: Amplifier Volume
CP: Crack Speed
CP: FX Amount
CP: FX Filter Cutoff
CP: FX Filter Resonance
CP: FX Filter Type
CP: FX Filter Type
CP: FX Filter Type
CP: FX Noise 1
CP: FX Noise 2
CP: FX Type
CP: Noise 1 / Noise 2
CP: Noise 1 Amp Env Speed
CP: Noise 1 Filter Cutoff
CP: Noise 1 Filter Resonance
CP: Noise 1 Filter Type
CP: Noise 1 Restart
CP: Noise 2 Amp Env Speed
CP: Noise 2 Filter Cutoff
CP: Noise 2 Filter Resonance
CP: Noise 2 Filter Type
CP: Noise 2 Restart
EP Drumatic CP Preset Loader
EP Drumatic CP Preset Saver
EP Drumatic HH Preset Loader
EP Drumatic HH Preset Saver
EP Drumatic SND Preset Loader
EP Drumatic SND Preset Saver
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC Float2Int
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC FloatCombiner
EP SC LastOut
EP SC LastOut
EP SC LastOut
EP SC LastOut
EP SC LastOut
EP SC LastOut
EP SC LastOut
EP SC LastOut
EP SC LastOut
HH: Amplifier Metal / Noise
HH: Amplifier Pan
HH: Amplifier Volume
HH: FX Amount
HH: FX Filter Cutoff
HH: FX Filter Resonance
HH: FX Filter Type
HH: FX Noise
HH: FX Tone
HH: FX Type
HH: Metal Env Speed
HH: Metal Harmonics Clip
HH: Metal Marmonics Depth
HH: Metal Marmonics Speed
HH: Metal Pitch
HH: Noise Amp Env Speed
HH: Noise Filter Cutoff
HH: Noise Filter Resonance
HH: Noise Filter Type
HH: Noise Restart
RIM: Amplifier Pan
RIM: Amplifier Tone / Noise
RIM: Amplifier Volume
RIM: FX Amount
RIM: FX Filter Cutoff
RIM: FX Filter Resonance
RIM: FX Filter Type
RIM: FX Filter Type
RIM: FX Filter Type
RIM: FX Noise
RIM: FX Tone
RIM: FX Type
RIM: Noise Amp Env Speed
RIM: Noise Filter Cutoff
RIM: Noise Filter Resonance
RIM: Noise Filter Type
RIM: Noise Restart
RIM: Osc Type
RIM: Tone Amp Env Hit
RIM: Tone Amp Env Precise
RIM: Tone Amp Env Speed
RIM: Tone Mod Env Depth
RIM: Tone Mod Env Speed
RIM: Tone Pitch
SD: Amplifier Pan
SD: Amplifier Tone / Noise
SD: Amplifier Volume
SD: FX Amount
SD: FX Filter Cutoff
SD: FX Filter Resonance
SD: FX Filter Type
SD: FX Filter Type
SD: FX Filter Type
SD: FX Noise
SD: FX Tone
SD: FX Type
SD: Noise Amp Env Speed
SD: Noise Filter Cutoff
SD: Noise Filter Resonance
SD: Noise Filter Type
SD: Noise Restart
SD: Osc Type
SD: Tone Amp Env Hit
SD: Tone Amp Env Precise
SD: Tone Amp Env Speed
SD: Tone Mod Env Depth
SD: Tone Mod Env Speed
SD: Tone Pitch
TM 1: Amplifier Pan
TM 1: Amplifier Tone / Noise
TM 1: Amplifier Volume
TM 1: FX Amount
TM 1: FX Filter Cutoff
TM 1: FX Filter Resonance
TM 1: FX Filter Type
TM 1: FX Noise
TM 1: FX Tone
TM 1: FX Type
TM 1: Noise Amp Env Speed
TM 1: Noise Filter Cutoff
TM 1: Noise Filter Resonance
TM 1: Noise Filter Type
TM 1: Noise Restart
TM 1: Osc Type
TM 1: Tone Amp Env Hit
TM 1: Tone Amp Env Precise
TM 1: Tone Amp Env Speed
TM 1: Tone Mod Env Depth
TM 1: Tone Mod Env Speed
TM 1: Tone Pitch
TM2: Amplifier Pan
TM2: Amplifier Tone / Noise
TM2: Amplifier Volume
TM2: FX Amount
TM2: FX Filter Cutoff
TM2: FX Filter Type
TM2: FX Filter Type
TM2: FX Filter Type
TM2: FX Noise
TM2: FX Tone
TM2: FX Type
TM2: Noise Amp Env Speed
TM2: Noise Filter Cutoff
TM2: Noise Filter Resonance
TM2: Noise Filter Type
TM2: Noise Restart
TM2: Osc Type
TM2: Tone Amp Env Hit
TM2: Tone Amp Env Precise
TM2: Tone Amp Env Speed
TM2: Tone Mod Env Depth
TM2: Tone Mod Env Speed
TM2: Tone Pitch
Unread post by woodslanding » 26 Mar 2010, 23:03
Thanks, that's great.
Much easier to eliminate unnecessary options than type the necessary ones by hand!
A lot of VSTs have very usable parameter lists, though. Not all are so random! In reaktor, the user can actually choose what's exposed in the parameter list--it's part of the same mechanism that assigns parameters to the preset manager.
So if you see 1000s of reaktor params, the inst builder hasn't done his homework!
Unread post by woodslanding » 21 Apr 2010, 09:23
How and when is the parameter list exported? I don't see lists for any of my vsts in the temp folder....
Unread post by woodslanding » 21 Apr 2010, 09:28
never mind, I found it!
One question, though--
I designed my reaktor instruments correctly, so the named parameters show up in the reaktor object within usine.... however, these same parameters do not show up in the .txt file.
Is there some way to make this work? I assume the txt file is written before the reaktor patch is loaded.
Indeed, I have two instances running in my wkp, and each has different parameter names.... but there is only one reaktor.txt
-e
Unread post by senso » 21 Apr 2010, 17:54
actually not easy to create the list after the reaktor patch is loaded.
I'll check it.
senso+++
Unread post by woodslanding » 21 Apr 2010, 18:25
Okay....
One note: the same situation exists with Kontakt.
Could you put a commatext output on the module for this purpose--would that be easier than writing the text file?
-e
Unread post by woodslanding » 21 Apr 2010, 19:51
I just tried the script and I am not getting updates of the fader positions. I am using v5.15, and I just re-downloaded the script to make sure I have the latest version.
Am I missing something? I'm using it completely unaltered..... just opened it in a new empty workspace.
Unread post by woodslanding » 21 Apr 2010, 19:55
I think I see:
when I change the combobox value, I get an update to the fader, but I don't get anything when I move the control in the vst.
Mostly, I'd like to see the fader update when the vst receives a patch change.....
I'll look at the IML and see if I can figure out how to do this.
gurulogic
Unread post by gurulogic » 13 Aug 2010, 23:09
I still don't understand this. I would very much like to have an output pin from the SetVst Param script that always reflected the VST parameter value when changed from the VST. I have seen 23fx23's example for manually updating the value from the VST but I would like it to be a continuous update from the VST. Is this possible?
Unread post by 23fx23 » 13 Aug 2010, 23:35
now that vst have array out, it should be possible to track element changes and update iml, ill give a shot...
