Page 1 of 1
Posted: 05 May 2009, 00:11
by 23fx23
Hope useful for someone:
relating the discussion we had in "gesture looper" thread I tried to build one
it's an Xy that start to record a pre-set nb of bar at a certain tempo anytime and then loop it. simple but the cool thingz added are:
_any new touch will increment changes to previous loop
_the speed can be dinamicaly changed to x2,X4, X8 ect to play only a part of the loop
_while playing one part (if at least in X2 mode) you can edit the non playing parts on the lines X or Y.
_then you can use the shift function incuded to reach those parts or simply shift the automation. (usefull as lfo)
_a random button with range and frequency can make each loop slighlty or drasticly different from previous
you can add a preset manager to set store and change on the fly differents loops.
big up to you bmoussay for advices and rollarray/random generator scripts.
add/ons/data tools
edit Ive just implemented quantisize on bar for speed changes and preset manager recall loops also on quantisize, too late now will update tomorrow.
Posted: 05 May 2009, 07:10
by nay-seven
great ! cool to see this idea growing up...!!
as we said in workshop , could be cool to add a wiki page and a little example on the way this tool could be used ( just a simple one for new users.. ;-)....? )
Posted: 05 May 2009, 10:27
by 23fx23
yupyou're right nay, gonna tweak it a bit tonight and reupload with wiki.
Posted: 06 May 2009, 01:10
by 23fx23
yop
deleted-reuploded new version: added quantizise for speed changes and preset recall
made a workspace with direct access example application controlling the cutoff of helios vst with a little interface builder.
wiki tomorrow or maybe a bit later as I think ill improve the random part a bit more, but I will need bmoussay/bsork skills ;)
Posted: 07 May 2009, 12:37
by fractal
Ah ! You made it !
This add on can help me to make some weird effect...
Thank's 23fx23 ! ;)
