this message just to say that I've uploaded a "note quantizer" in the add-on section.
You can find it here.
http://www.sensomusic.com/download.php? ... 0addon.pat
Here's a short description:
Hello, this add-on is a simple note quantizer, that means you send in some pitch (data or midi), you select some tones on a keyboard, and it rounds the input pitch to the selected notes with selectable root, octave range, and an integrated step module to make it work standalone. I find it very useful to create melodies, arpeggios, etc... It's like an expanded function of the "scale and root" function of the midi transformer, since you can choose any note combination. I've added a few presets for common scales and chords. Any comments or suggestions are welcome.
Regards, B.
Note quantizer
nelson
great work!
that was my sugestion to improve midi transform module - but now your patch do this well
please add more "exotic" non-european scales as presets if you can...
Clearscreen
WOW! great work mate - i've been thinking about doing something like this but didn't know where to start! thanks for this
