Tempo to ms
ethnix73
Unread post by ethnix73 » 07 Oct 2008, 22:15
Tempo to milliseconds
A simple Patch to synchronise your delay. Use the /2 or x2 to double or half the tempo.
If you want to set it manually, press the manual switch.
In order to save your settings within the patch, you've got to press the manual switch,
once you're ok with you tempo. And doesn't forget to put a master or sync module in your parent patch
to synchronise it
I've discovered after making this patch, that there was yet one in Usine...but that was not a reason to not sharing it.
It's in synchro and time tools
Seb.Dub
Unread post by senso » 07 Oct 2008, 22:16
cool!!
