About User modules and Layouts
moody33
Unread post by moody33 » 12 Jan 2009, 20:37
hi !
I've download nelson's scalesnap and I've paste it into usine folder modules->user. But It don't works . i've got this message " procedure failed in: " What i've missed?
Where to paste layouts? I've download Vincent layouts, but I don't know in which folder i've to paste it.
Thanks;
Unread post by nay-seven » 12 Jan 2009, 21:22
for the scalesnap , just retry to download it maybe ..cause this works ( just recheck it and no problem )
for the layouts , yes , it's not logic ( for me ) , but put it in the skin dir...works better...;-)
senso..?
moody33
Unread post by moody33 » 12 Jan 2009, 21:42
I've re-test, and I have the same problem with the new nelson addon arrayXY....
nelson
Unread post by nelson » 12 Jan 2009, 21:45
strange ... someone have similar problem?
moody33
Unread post by moody33 » 12 Jan 2009, 21:48
Hi nelson. I've also noticed that in usine, when i open the user module folder, your modules appears whitout any name. There only blank...in place of letters.
Unread post by nay-seven » 12 Jan 2009, 22:03
no problem here , usine beta8.....?
moody33
Unread post by moody33 » 12 Jan 2009, 22:09
nay-seven wrote:no problem here , usine beta8.....?
Yes, beta8
martignasse
Unread post by martignasse » 12 Jan 2009, 22:17
I experienced similar problems with user modules...
and it was because runtime library of VC++ wasn't on the computer.
here a link to the Microsoft Visual C++ 2008 SP1 Redistributable Package : http://www.microsoft.com/downloads/details.aspx?FamilyID=A5C84275-3B97-4AB7-A40D-3802B2AF5FC2&displaylang=fr
sorry, in french.
hope it help.
edit : link to the English page added to the WIKI :D
Unread post by senso » 12 Jan 2009, 22:34
Any solution to compile User modules with the redistributable package included in the code?
moody33
Unread post by moody33 » 12 Jan 2009, 22:38
I've download martignasse Link (thanks). It works now for scalesnap but not for array xy.
martignasse
Unread post by martignasse » 12 Jan 2009, 22:55
senso wrote:Any solution to compile User modules with the redistributable package included in the code?
As far as i know, no other solution, because these library are runtime library of the Microsoft C++ compiler (for a specific version), and Microsoft provide them only in dll.
edit :
ok, in fact, it's possible to compile User Module with static linking of runtime library :rolleyes:
I made a quick test with the PrototypeExample (size jump from 9Ko to 61 Ko) and dependency walker not mention any more microsoft runtime dll as dependency.
To achieve this, you have to go in the project properties->C/C++->Code Generation : and change 'Multi-threaded DLL (/MD)' to 'Multi-threaded (/MT)'. and recompile.
Have to make some further test, but it seems to be the solution.
moody33
Unread post by moody33 » 12 Jan 2009, 23:57
Great news. If it work, it should be great if all users modules available for download could be updated .
Clearscreen
Unread post by Clearscreen » 13 Jan 2009, 04:04
moody33 wrote:Hi nelson. I've also noticed that in usine, when i open the user module folder, your modules appears whitout any name. There only blank...in place of letters.
just noticed this with the XY Array add-on myself...
martignasse
Unread post by martignasse » 13 Jan 2009, 09:28
moody33 wrote:Great news. If it work, it should be great if all users modules available for download could be updated .
Ok, cool,
thanks for the feedback
An SDK update seems needed to reflect this...
Unread post by senso » 13 Jan 2009, 09:34
yes good idea
Users browsing this forum: No registered users and 61 guests
