Leap, HH6, M4
Leap, HH6, M4
Unread post by gwennaelle » 23 Mar 2026, 15:34
I've been using the Leap and Usine's modules, but it doesn't work now with Usine version MacOS-M-Series 6.0.250506 on an M4 Pro, Mac OS Sequoia version 15.7.1.72.
Is there a driver or update that needs to be installed?
Thank you for your reply
Gwennaelle
Unread post by 23fx23 » 23 Mar 2026, 20:22
If i rem correctly, if using latest ultaleap v5xx gemini driver need to install/use the ultraleap usine module in addons, not the leap one which only works till orion v3xxx driver (at least on win, so might be same on mac) or if wanna use build in leap module need to install older orion driver
Unread post by gwennaelle » 25 Mar 2026, 10:14
Thank you for your reply.
I haven't find v5xx gemini driver, but I found tracking-software-apple-silicon-6.2.0 and Leap_Motion_Setup_Mac_2.3.1, and I've installed the UltraLeap add-on.
I don't know if this is what you were suggesting, but my hands are being recognized—it works.
Now I have to build the UltraLeap patch.
I’m not used to working with arrays. My initial tests to link hand or finger gestures to audio parameters doesn't work.
Would anyone have a template?
Or I've seen the idea of using Geco. Is that an alternative?
If you have an idea, please let me know :-)
Unread post by grego mondo » 25 Mar 2026, 10:52
May be it's a good opportunitie to get involved with Arrays :-)
I believe you can't really "faire l'impasse" on Arrays because it's such a powerfull tool !
There it looks you can get number of hands valids (> palms) recognized (1 or 2)
From there you can know wich value of the Array you're intereseted in (first or second)
I guess you can even reorganize dynamically the values order > so when 2 hands are recognized : the first value is always the one with the smaller x value (the one one the left) ...
May be you'll spend more time today learning to work with Arrays but you'll be quicker next time and you'll learn powerfull tools
Il est toujours bon d'apprendre à pêcher ;-)
BM2F
Unread post by BM2F » 27 Mar 2026, 11:25
Hello gwennaelle,
did you saw the addon about leap ? Some audio patch
can be a good start
have a nice patching !
