Enhanced Player audio with template
joffo78
Unread post by joffo78 » 31 Aug 2025, 15:24
Here is an audio player optimized for theater and radio projects, but not only.
This patch, which can be added to your templates, offers a better experience for playing your audio files than the standard player.
- Playback and stop are triggered by a switch, which facilitates automation.
- The loop function is a separate mode, which allows you to trigger or stop playback without deactivating this mode.
- Another loop mode (marker loop) allows you to specify multiple loop points. When this mode is activated, a “release” button appears, which allows you to exit the loop smoothly.
- A pause function is available.
- A fade-in start and fade-out stop are possible.
- All player settings (pitch, gain, in, out, loop mode, etc.) are stored individually for each file on the list.
- From a pop-up menu, you can access the total file time as well as the elapsed time and remaining time expressed in h, m, s.
- Also from the pop-up menu, you have a vinyl-style start and stop effect (gadget) with adjustable duration and start or end pitch.
Have fun!
joffo78
Unread post by joffo78 » 31 Aug 2025, 15:25
Have fun!
playertheatre iml template.zip
(19.59 KiB) Downloaded 171 times
Unread post by cmodica » 01 Sep 2025, 15:34
Wahou ! Wonderful player and it is very useful.
Thank you very much to share this tool.
The same with a sampler recorder should be fantastic. 8)
Have a nice day.
damstraversaz
Unread post by damstraversaz » 02 Sep 2025, 10:43
that's really great, thanks a lot !
joffo78
Unread post by joffo78 » 02 Sep 2025, 11:27
Thanhk for your feedback !
joffo78
Unread post by joffo78 » 02 Sep 2025, 11:28
cmodica wrote:
01 Sep 2025, 15:34
Have a nice day.
I think you ve just to replace the module
Unread post by rlgsbt » 02 Sep 2025, 14:23
Nice ! thanks
Unread post by cmodica » 03 Sep 2025, 09:21
joffo78 wrote:
02 Sep 2025, 11:28
cmodica wrote:
01 Sep 2025, 15:34
Have a nice day.
Yes, i will try as soon as i can.
sometimes, when i replace a module, some connections are broken ...
I will tell you.
Thank you very much
Unread post by oli_lab » 05 Sep 2025, 23:14
Great job !
I'm sure now that global arrays have no secret for you !
definitely will steal the "release" concept for some live improv situation.
here's a method to set, save and retrieve the markers as text files (.mkrs) in the same folder as the wave file.
save markers in text files.pat
(41.07 KiB) Downloaded 178 times
enjoy !
Unread post by oli_lab » 07 Sep 2025, 18:16
I merged the release ideas with the saving of markers as text files thingo and I published a new addon !
Users browsing this forum: No registered users and 100 guests
