Rhythm Box beta release
Unread post by oli_lab » 06 Nov 2024, 23:00
Just made this new module, so each Usinianer(!) can fidle with rhythms !
based on this YT vidéo from IRCAM : https://youtu.be/indkKkGX5wg?si=4Y2ypoaLmNXT_JvU
It is not very different from the sequenced switches, except it is round.
enjoy
Unread post by rlgsbt » 07 Nov 2024, 09:40
Super boulot et plein de perspectives en vues ! (et pas que polyrythmiques...)
J'ai testé et j'ai un problème avec les envois de trigOut. il faut passer par un Pass if Change pour avoir un trigger propre, sinon, il les multiplie.
Voici un patch qui est plus simples à comprendre..
RhythmBox+Pass.pat
(38.81 KiB) Downloaded 412 times
Encore merci pour le partage
Unread post by oli_lab » 07 Nov 2024, 18:36
rlgsbt wrote:
07 Nov 2024, 09:40
Merci pour le retour,
effectivement, le trigout reste à 1 sur plusieurs cycles, je vais corriger.
Cependant, en attendant, il faut mettre un flow from 0 to 1
Unread post by oli_lab » 07 Nov 2024, 19:21
improved beta version !
Unread post by grego mondo » 12 Nov 2024, 07:52
J'adore
merci
Unread post by oli_lab » 12 Nov 2024, 22:37
but wait, there's more :
I did a pattern generator that is capable of total random towards euclidien rhythms.
As well as some exemple of a pattern delay
exemples are still sketchy but.
Dj Olivar.
Unread post by oli_lab » 16 Nov 2024, 00:46
It is now an addon !
Unread post by cmodica » 19 Nov 2024, 12:05
I tested it quickly. It looks really great.
Thanks a lot.
Unread post by oli_lab » 19 Nov 2024, 20:29
Hello !
I was thinking of doing another module on the same principle but with knobs instead of switches.
what do you reckon ?
damstraversaz
Unread post by damstraversaz » 24 Feb 2025, 11:38
that's really great, thanks a lot !
