Arpix with Touch-device
halbius
Unread post by halbius » 27 Apr 2024, 08:58
I really love using Arpix.
Now I would love to control it via a touch device like a tablet / smartphone.
Is there something already available?
Or do I have do built it with TouchOSC (or similar), which I think will be quite challenging?
Thanks a lot!
Unread post by senso » 29 Apr 2024, 09:47
hi, Usine is fully compatible with touch screens. But unfortunately touch screens are only available on Windows.
If you have a PC, it's easy just connect de small touch-screen.
On Mac you can use a small utilities to extend the screen of the computer with an iPad, then put Arpix inside the "toolbox" and the "toolbox" on the iPad screen.
It's challenging to create a TouchOSC layout to control arpix... not impossible... but you'll spend a lot of time.
halbius
Unread post by halbius » 01 May 2024, 11:55
I am using windows.
But I only found the option to enable "real" touch screens, like mentioned in this thread.
Is that possible with an android tablet? Can I enable it in Usine as touch device? It works with extra utilities to add the tablet as a second screen, like you described for Mac.
But as I understand, it should work directly with windows?
