My basic pitch shifter in the add'ons section ( audio effects).
Cheers.
Moody Pitch Shifter ( Mono ; VST format)
Thanks Moody33!
I'll try it tonight.
vincent michel
composer & novelist
composer & novelist
hi moody33,
your pitch shifter is cool but very close to the Library one. I mean made with a granular re-synthesis.
So it introduces a 'smearing' (grainy sound) effect for Hi pitches.
The pvTransp is made with a FFT Phase vocoder algorithm, which I think is is smoother. The main drawbacks are the cpu load and the latency....
