Like my last upload, this is based on gurulogic's parameter control idea, where parameters are kept in a local loop, and manipulated externally.
To use, first wire up your vsts as shown. Then open one of the vsts (as there is no mousedown for a vst, it is crucial that only one vst is open, so the mapper knows which one to map to.)
To map, click the map button, then one of the sliders in the bank (you do not need to move it, it is just looking for a mousedown) and then move the desired control on the vst. Your fader should be renamed by parameter, and recolored by vst color, and the learn button should turn off.
http://www.sensomusic.com/forums/upload ... hLearn.wkp
Hope this is useful to someone!
cheers,
-eric
Multi-vst parameter mapper with Learn
Cool, I will study this more closely. Thanks!
I also posted one of these without learn but with LFOs. in the original thread....
You can have both, but you must turn off LFOs when learning.
I suppose that could be done programmatically. Maybe I'll upload an improved version.
